Test Vivi 3000+ LBBLE 0520 APMW :
OCCT stable a 2600mhz a 1.39v
OCCT stable a 2700mhz a 1.54v
OCCT stable a 2750mhz a 1.61v :) (70% at the moment)
Aircooling -> XP90C + Vantec Tornado 92mm (119cfm) (56dcb)
Has already proven the PI 32M?Quote:
Originally Posted by boblemagnifique
Until soon
Just paid for an 3200+ 0520BPMW and will post screenies here first when it gets here with my new Ultra D :)
I really think the thread title should be changed to include 3200+ AND 3500+, not everyone buys JUST 3000+ :)
Prime it, I can OCCT stable about 1.64 but need 1.69 to get prime stable.
yes I would test in water because the tornado gives me head badly too a long time, and considering I sleep with, I cut it the nightQuote:
Originally Posted by dnottis
at home when OCCT passes, Prime passes without problem during more than 6 hours
APBW 0520 006er batchcode
2700mhz 1.39v primestable
2800mhz 1.48v primestable
2855mhz 1.55v primestable
2900mhz 1.58v benchstable
2855mhz 1.44v superpi 1m stable *g*
The heatspeader is down and cooled by watercooling with tipple radi and nexxxos xp rev 2.0
Friend just got a week 17 3200+, not seen many results, well actually I have only seen 1!
Will let you know!
good results, any screen?Quote:
Originally Posted by Riverna
I looking a 0520 APMW, which is a good estepping but APBW apparently is better
venice 3000+ @ dfi lanparty nf3 ultra-d on air cooling
http://img11.imageshack.us/img11/5750/17td1ik.th.jpg
My result for so far...
I cant get futher because my mobo failed on me :(
So i wait till it get back from RMA :banana:
PMWs and PAWs are the best but some are bad apples (and vice versa for other steppings). i'd get the APMW....Quote:
Originally Posted by matrs
jus got it two days ago and it seems to be loosening up . very happy with my week 20 , it kills my week 16 , sry guys i didnt write down teh stepping but heres a screenie .
http://img239.imageshack.us/img239/3604/300x94it.th.jpg
i got a 3000+ 0520Cpaw runnigh 2550mhz right now..hoping for 2700mhz:9
Btw..Where can i get that program IDLE?
It's called SP or Stress Prime 2004 and you can get it at http://sp2004.fre3.com/
THanks ;)
Newegg/PIB-06/28/05
2800, 9x311 @ 1.55v
0520 CPCW
http://img55.imageshack.us/img55/984...28002cx.th.jpg
Finally managed some time to do a little OCing :)
3200+ 0520BPMW
DFI Ultra D
2x512 OCZ PC3200EL R2
Bios 704-3
check out the Vcore :banana: hehe, next I will see how high it will go
http://img301.imageshack.us/img301/1...htt26186xm.jpg
LBBLE 0520 DPAW (I believe it's a PAW at least, don't wanna take it out but I'm 90% sure of that). I ran 600 runs of lobby low with prime running in the background while I went to work came home to find no errors. It's running a 133 memory divider because I'm on the DFI NF3 Ultra-D and didn't wanna worry about ram giving me problems. I cannot verify the voltage, temps I don't know either bios says about 42c whenever I check, seems accurate enough. Cooling is an arctic Freezer 64. I ran prime at 2800mhz and no errors for a couple hours, but lobby froze on me about 2 hours in. And at 2850mhz it bsods right away, wierd. I 'm guessing it's a mobo issue.
http://img249.imageshack.us/img249/5...0venice6mi.jpg
here's mine and I can go prolly a bit higher with frequency..and laso the time..i was just trying to see if it was stable :)
020 EPMW
:banana: liquid with radiator @40°C after the test
http://img154.imageshack.us/img154/1331/310x92it.jpg
I've got a Venice 3200+ 0521GPKW...results tomorow :)
there's another thread for week 21 resultsQuote:
Originally Posted by Supertim0r
http://www.xtremesystems.org/forums/...ad.php?t=67298
looking forward to seeing them :toast:
Check some French 3000+Venice out, :fact: week-517, 3487Mhz (screen) :toast: Prim95 stable at 3000ghz, SuperPIfast 1M = 27s at 3126Mhz, CPUmark score:402 at 3317Mhz :slobber: All this with water,cooling :yepp: :worship:
http://www.lesfurieux.net/forum/inde...ST&f=10&t=976&
It seem that my 3200+ 0520BPMW does not scale well with Vcore, also i think the mem controller is BAD on this CPU, I can use any type of torture with these settings and its rock solid stable but if I try ANY Pi over the 1MB it craps out :( , Its not my ram because it does the same when using a divider :slapass:
http://img106.imageshack.us/img106/1941/pi27000zb.jpg
Just picked up a 0520CPAW 3000+. Still waiting on my motherboard, but shoulod have some results in a couple days. I'll post them when I have them.
I have a Lbble 0520 dpdw clocks 2.7ghz at 1.52 on air and 2.8ghz on water at 1.65
