Well i ran it outside with watercooling lastnight and it seems over voltage protection is kicking in around around 2.05v. If you have decent aircooling i would think 1.8v to bench wouldn't be asking too much provided you aren't seeing over 50c temps on load. When i was on air with i peaked at 48-50c indoors with a normal ambient temps so i would use that as a guide to "decent aircooling". Higher than that then you probably don't have enough airflow around the card or poor contact on the GPU. Right now i've left the GPU set at 1.77v in 3d with 622/1250 set as my clocks for 24/7 opteration.(ATI tool shows arti free up to 640 core) Peak load temps are 38c which badly beat down the stock coolers max that was over 70c at defalt clocks.
