Originally Posted by drunkenmaster
Nope in USA, got it from TT direct for review (to come @ www.3dxtreme.net ). ;)
do'h, any idea when both the typhoon and the big ass tower(ok can't remember the official name, though i think what i said works well :p ) will be widely available?
http://www.newegg.com/Product/Produc...82E16835106061
As dnottis said, it(Big Tsunami) is available at newegg, also they've had it at least for a month. I remember checking TT's site and then newegg for it.Quote:
The SonicTower is available here, but is currently out of stock. :(
Damn clips never gave good enough clamping for bare dies, my hyper6 dropped temps by 10c. :shock2: May get one myself (thinks about stack of 120mm fans @ home).Quote:
Originally Posted by dnottis
Ordered the TT Sonic Tower tonight :D After my Sandy finally comes, I'll probably report some air results.
Wow thats a monster.. nice results :)
@ dnottis
will the TT allow you to mount to a "naked" core ? without IHS ?
I might give it a try ;)
No, I've mounted it directly onto the core, with out heatspreader. No problem so far and great performance. Really a great cooler. I've build this machine for my neighbours. I think they'll be very happy if I deliver it tomorrow :)Quote:
Originally Posted by lastdon00
its says it works for socket a so would that fit on my sempron?
ild love to push it
Originally Posted by Major
ya, I dont see why it wouldnt. the stock DFI Ultra-D backplate doesn't work though, the posts are too short. I had to stick another one I had laying around onto the board but it screws down so whether or not there is a IHS shouldn't matter.
Dean
Nice, I'm going to order one tomorrow and compare with XP120Quote:
Also, were the screws too short ? is that why you had to use the metal back plate ?
http://www.3dxtreme.net/other/ontap/...r/IMG_1217.jpgQuote:
The screws were fine the backplate the DFI board uses isn't standard and the posts are too short.
With another "standard" back plate they reached just fine... again longer screws would fix it, but the problem isn't the screws it's the backplate included with the DFI board.
Also, check your PMs ;)
Dean
so u have to move the rentetion bracket not on the under side, that the stock heatsink goes , so u can install this or can u leave it on?
no, u have to replace the bottom retention plate that comes through the holes on the mobo. The yellow one that comes on the DFI has short posts that wont allow the screws to reach.Quote:
I think I'll go to ACE hardware or Lowe's before I yank the mb out ! lolQuote:
IMO they may be long enough to reach anyway with the IHS removed.
i wonder how it is ont he asus a8n- deluxe.. i was thinking of getting this cooler..
So wait...I need to have another backplate on hand in order to install this on my soon to arrive DFI NF4??? :slapass:
ordered one from Newegg, looks nice and IMO will outperfom the XP120 I'm using based on the reviews.
so this one is better then xp90 ?
i have zalman 7000b-alcu right one ?
what should i get
xp90 or this TT BIG ?
TT BIG ftw :banana:
Read earlier in the thread, there was a link to a review where there were 2 dozens of cpu coolers compared side by side including Thermalright's XP90, XP90c (which in fact outperforms XP120), XP120, and Thermaltake's Sonic Tower as well as Big Typhoon.Quote:
Originally Posted by TEDY
Thermaltake's cooler that actually delivers - their first i think :)
Anyways, my choice would be CoolerMaster's Hyper6.
interesting... it perform @ only 16db of noise... :woot:
will it fit in an antec super lanboy?
