Isn't there was also some kind of program that allows changing of the Vcore in windows?Quote:
GRATE...... :D
macci couldn't the multies of the CPU be chanched within bios?....
Im gonna go Dothan. It'll almost be costless for me...Quote:
Originally Posted by macci
But Im worried about the noise of that adapter stock fan as I would like a sub 20db rig (that would be one of the nice things about getting a Dothan!). Would it be possible to keep the Dothan cool enough at 2/3 speed or even 1/2 speed on that fan?
And, can PAT (or whatever its called on Asus boards) be enabled on 865PE fx. the P4P800SE?
awsome! :slobber: :toast:
yes but only for lower Vcore values.Quote:
not with the boards and BIOSes i've tried. But it works from windows (lower multipliers).Quote:
Originally Posted by hipro5
yesQuote:
Running the fan at 7V or even 5V should not be a problem. Dothan TDP is like 27W or so =)Quote:
Excellent!
Im not much of a modder, more of a Booster guy :). Would I be able to go anywhere vcore-wise without the need to mod the P4P800SE?
3ghz still liquid cooled??? amazing....i think i am ordering a 730 :D
i think we will have a new 3dmark01 record soon with a dothan...
Dothan is very nice chip :D cong macci :toast: scores are awesome :woot:
what happens if you apply a ln2 to this cpu :rolleyes:
Nice :slobber:
Yet..... this is macci that we're talking about here, and the chip is still under pelt and water? :D
How long before slightly colder substances are used? ;)
wow great results there..
but where to get the CT-479 adapter ?
edit : nevermind, allready found it @ewiz.com & atacom.com
Damn! :eek: Running a rig with four 65nm Pentium-M cores would be ownage in its purest form :DQuote:
Originally Posted by FUGGER
Is this just for the P4Cs? I mean, this doesn't affect the P4P boards, right?Quote:
Right, it doesn't. According to this test, the P4P800 boards has vcore adjustments up to 1.6!Quote:
Originally Posted by uclajd
We need a thread summing up and organising all of this info. Seems as if Dothan overclocking is getting more mainstream...
Apart from that, we need BIOS version with more cpu/dram ratios, giving the possibility to utilize those BH5/UTTs and TCCD we all have laying around without the need to go totally 220+ extreme on the FSB...
Nice work! now just grab a 6800 Ultra and try to catch Opp and Shamino in 3Dmark 03. :)
I think he will catch them...
I believe chilly told me that those dothans can run without a heatsink and not get to hot in temp...so even being passive cooled they will run very cool.
Sweet. Just bought one. I'll be picking up a 760 Friday for my P4P800-DX, hee hee. Hope I can figger out how to mount a phase block on this puppy.
The question is, cascade on the CPU and Vapo on the GPU, or the other way around? :slobber:Quote:
Originally Posted by stryg
congrats macci! :toast:
hmmm gotta find me a place that sells those boards already flashed with the new bios hmmm
Maybe since the CPU runs very cooly, u could try the Vapo on the CPU & Cascade on the VGA for 03 and 05, then switch it for 01, since 01 is mostly cpu intensive. Go for #1 Macci.Quote:
Yeah, that's the plan, but since the X800 XTPE is already bundled up with the cascade, I'll go that way (Vapo on CPU) first...Quote:
Originally Posted by moddolicous
Hey :]
I have a few questions:
1) Is there any difference between the P4C-E DLX or the non -E DLX?
2) Sould I go for 730 + P4C800 E or 740 + P4P800SE?
3) is there any OC potencial difference between the 740 and the 730?
My needs are: highest OC that can be reached with Air cooling.
the budget is limited so i can't buy 740 & P4C...
The answer to number 2 depends on how much you want to spend and whether you care if your processor has a 12x or 13x multiplier.Quote:
Originally Posted by Venom21
I said that I can't buy 740 with P4C, anything else is posibble.Quote:
Originally Posted by DrJay
And the multiplier can be adjusted in EIST (am i right?), so i guess it's not really matter.
whats really mattar is if there any OC potencial difference between the 2 CPUs.
and if i should go for 730 + P4c or 740 + P4P.
Actually it does matter a bit since for optimal performance you want to boot at atleast 200FSB (BIOS doesnt' have multi options, at the moment atleast). So for 730 your CPU needs to hit 2400MHz and for 740 2600MHz. I'd say that getting a 730 that will reach 2400 is more likely than getting a 740 that does 2600MHz. Both models have good and bad overclockers. You need to be lucky :)Quote:
I'd go for 730 + P4C
