And about ZALMAN ZM-NB47J?
http://www.nuxpress.com/admini/immag..._nb47j_c_p.jpg
I MUST change chipset cooler ... with DFI stock cooler at 300x8 I reach 53°-54° :(
I have an ASUS AX800XL and the DFI Ultra-D mobo and the clearance between the chipset and the card is basically 0! The card is touching the chipset fan and sometimes it'll make those weird noises, like when you put your finger in a spinning fan. If the card isn't mounted correctly you could complete stop the chipset fan. So those out there that may be hearing that weird noise or notice you have high chipset temperatures, check to see how close your videocard is to the chipset fan because the fan could be stuck on the card. I really hope I don't have to do any modding to this thing so everything works nice.Quote:
Originally Posted by dnottis
It's possible to put pci-e card in the second pci-e slot so they don't touch ... I have moved mine X800XL and I have set jumpers to SLI mode so second pci-e works @ 8x without differences in performance :toast:Quote:
Originally Posted by Techwarrior
Awesome! I didn't know that! Do you have to move the jumpers to SLI mode for it to work @ 8x?Quote:
Originally Posted by XiN
Exactly. In SLI mode both slots works @ 8x and the difference in perfomance between 8x and 16x is about 1%-2% :DQuote:
Without moving jumpers, instead, second slot works at 4x (or 2x I don't remember ...)
But that will also not make a performance differnce try it out and you will see..they really dont NEED that much bandwidth...
Dragon
Just a small tid-bit, for those who don't know:
There is a measurable and real performance difference in SELECTED 3D apps between 8x and 16x PCI-E lanes.
In games this is rarely if ever visible, but in certain 3D apps the difference is there.
Just FYI.
What kind of 3D apps? 3D graphics apps?Quote:
Originally Posted by halcyon
I use one but i had to remove some pins, and bend anothers. It's working same temps stock cooler, but dead silent.Quote:
The graphics card fits in the middle of the zalman.
That Artic cooling chipset looks awsome, probably will keep temps like 30ºC also!
3D Modelling (pro) apps, but yes some games also show the miniscule performance difference as written above by others:Quote:
http://www.tomshardware.de/graphic/2...nalyse-09.html
Is vantec iceberg really better than the stock one????? The stock one looks more beefier.
My max chipset temp is about 45C, that's with room temp over 30C (summer in LA no AC, gotta love it) and under fool load (Prime95 Custom Blend)?
Ok...
MadMikeSS tried moving video card to the other slot and lost significant performance - so it's not worth it. Just finally ripped my rig apart today replaced the chipset cooler with the Vantec Iceberg. Chipset idle now is 34, load 39, about 10 deg lower - oh ya and used AS5 Tim (but I was using that with the stock chipset cooler too).
Anyways heres a look -
http://www.3dxtreme.net/other/ontap/...r/IMG_1222.jpg
aua, and that is so cool' i like it a lot :toast:Quote:
Originally Posted by kiwi
anybody tried the "ICEBERQ 4 PRO" or "ICEBERQ 5"?
They are supposivley better if they can fit.
Looks like very goodQuote:
hi how about with stock n as5 :toast:
It will help a bit, but get a cooler like my spire or the vantec iceberq4. It holds my chipset to ~35C with chipset @ 1.7V.Quote:
Originally Posted by DjiNN
So far from what I'm seeing the ICEBERQ4 PRO doesn't fit. You need the ICEBERQ4. I just picked one up today and I will try fitting it to motherboard. A lil dremel work must be done but nothing too hardcore. I really need to find my AS5 though.Quote:
Originally Posted by SHiRaKaWa
now i did it as5 n stock cooling... and it seems fact it only 1C :confused:
it was 47 befor as5 an now it is 46 :slapass: :D 270 x4 htt n 1,5 v
A small L shaped heatpipe solution that can be mounted in 3 different directions would solve all problems with heat and placement of chipset on any motherboard.
I was already doing that - wasnt any good.Quote:
temps were like 40 - 48
Well theres two fingers to those who said it doesnt fit :p:Quote:
Nice and neat with the power lead too there!
Its 2x. I thought I saw something in the manual that suggested there was a way to jumper the 2nd slot to 16x?Quote:
switch the jumpers to SLI and it becomes 8x. no performance hit visible with my x700. infact, I beat my previous 3dmark record with it in this spot. :DQuote:
Originally Posted by ewitte
I'm working on that as we speak. I've got an aerocool vgacooler that needs a little work fitting on the chipset....Quote:
Originally Posted by Ubermann
