OPB when oh when can I purchase this ram?
Wow, those look great.
Originally Posted by chunkylover77
Couple days later I think! :)
Is it good or bad idea to put some copper heatspreaders on this memory ?
That is... went back and re-verified log book with fresh run... numbers same, 3199MB/s. Ran with 180 divider, get 3014MB/s. Also no dif for 2.5-3-3-6 vs 2.5-3-3-7. Point of reference, rest of major timings at that time were 3-2-2-2 (Trtw, Twtr, Trr, Twr), interleave on, 256 IdleCnt, Tref=4708, Trc=11, Trfc=14.Quote:
Originally Posted by eva2000
What version of memtest did you use Eva? (I was using V1.51)
--- Sonic ---
What did you do dif between 1st screen and 2nd two? (3297 vs 3199)
--- Ubermann ---
Looks that way and would be in the right range...
--- Perkam ---
Not necessarily regarding Vmem... only took 2.6 setting for 300M ;) My experience with TCCD is that Vmem dif from 300 to 330 usually is nada to 0.1V.
--- OPB/kakaroto ---
No comment to post 43? :stick:
FYI... you might try bumping Vcore by .05 or so, it can help sometimes on borderline timings for the mc ;)Quote:
Originally Posted by kakaroto
was using memtest86+ v1.55.1 as it fixes all the bugs in prior versions
300HTT with 270mhz 2.5-3-3-6 1T 7-14-2-2-1-2 3072 Interleave On
forget what combo but secondary timings are what make difference, also MAL, etc. Never could get it to be stable @ 3297. One last note: if you tighten up every thing right and you can get it to work, you can get 3405 in memtest @ 2.5-3-3-6/7 :brick:
Why does everyone bother with Memtest? I use it only to see if the memory is not faulty. If I get no errors at stock speed, then I ditch it and go straight into Windows. And play, test it there.
Sorry, but in my opinion Memtest screens are totally useless and proof nothing. You can hang me now :lol:
*me hangs michal by his DIMMs* :p:
Notice my earlier comments regarding stability bro ;) Regarding memtest... it's handy and quick loading, doesn't require a HD (corruption possibilities during "hairy edge hunting"), allows quick access to the BIOS (no windows tool gives access to everything in BIOS), and is useful for finding a starting point... i.e. if it pukes there you can forget Win. Note: S&M can also run from an image.
--- Eva ---
You're answer tells the why to the dif ;)
@EMC2
You right, it's to determne a starting point. If it's good there, then off we go to Windows! That's what matters, who cares that I might be error free @ whatever speed when I get to Windows (ultimate goal, right?) and it's nowhere near stable there.
Oh, btw... If anyone wants to know... I just checked bandwidth on my BH-5 @ 270x10 5-2-2-2.0-1T and also got 3199MB/s... :confused:
that's about right..Quote:
Originally Posted by bachus_anonym
from what i can tell i can now understand why gskill like ram even at 2.5-3-3-7 1T at 275+ can be so close to BH-5 ram it's bank interleave that does it, Gskill can handle bank interleaving on gives it a nice boost, BH-5 usually didn't handle bank interleaving at all but with 414-2 I tried BH-5 handles bank interleave upto around 240mhz 2-2-2-6 and gets a nice boost past 240+mhz bank interleave off and it's up to the advance timings to be tightened for BH-5 to fly.
i.e. BH-5 @ 10x 240mhz 2-2-2-6 with bank interleave on = 3026MB/s in memtest :)
Originally Posted by EMC2
Hi my friend,
I am not sure what you mean, but hey, here is my test, I 've never BS to XS friends here. FX55 does memtest BW really LOW, I mean really low.
here is what I ran from air cooled fx55(Mach 2 died)
below all done by only 2.63v(2.6+0.03)
how about 64 passed test5:
http://img258.echo.cx/img258/9584/gsffmt56vf.jpg
ah...aslo 32 passed for memtest 8:
http://img258.echo.cx/img258/2252/gsmt87et.jpg
so is that stable enough?
Kevin, can you pretty please run SuperPi 32M @ same clocks us shown on Memtest screen? 300x7=2700MHz DDR600 6-3-3-2.5-1T ?Quote:
Originally Posted by Onepagebook
You will have one less off your back :)
Thanx
EDIT: Or... "Memtest for Windows" screen, like you have shown couple weeks ago with PC4800LA 2x256MB @ DDR600 5-3-3-2.5-1T ;) That was some nice 2700%, (~60minutes) my friend :thumbsup:
EDIT: Look what I just found on Gskill's website, press release... Whoever did that, props to him :)
http://www.gskill.com/images/ffw600.jpg
So, now we just need a screenie like that, but @ DDR600 7-3-3-2.5-1T :toast:
Give you that tomorrow buddy.:D
...tsssssz... Roger that ...tsssssz...Quote:
Don't know I would agree Windows is ultimate goal :hehe: It's also good for sorting out new mem quickly for "edge points" on various advanced timings for later tweaking in OS ;)Quote:
Maybe 3199MB/s is hardcoded value :lol: Naw, looked at the source code... no errors, just too small of test for minor diffs and only a looks at burst speed...
OPB... please don't misunderstand, was NOT implying any BS! :)Quote:
Sorry to hear about your Mach2 death :( Don't have your new black&blue yet?
Regarding my comments... was curious why the smudge out on wall time, I am part cat after all :p: But mainly, just noting that memtest runs, even 30 min or even 1 hour ones, is not a good indicator of bench (say pi32m or some gfx benches) or 24/7 stability for users. You know from your "race" with Michal before that stability for some benches can be a real beach ;) In consideration of you being a representative for GSkill and the total readership here, thought it would be good to show more than memtest runs is all :D
addition: Would also be good to state full timings for your runs, even if memtest ;)
414-3 bios gave my gskill PC4400LE a bit of boost in bandwidth by 100+ MB/s and a bit higher oc
9x 296mhz 2.5-3-3-7 10-19-3-2-2-4 with Max Async Latency = 8ns with 3200+ CBBHD 0445 VPMW winnie
K...fully understand now,
Tomorrow, I will get my best to get a 3000+ on it. you will know what's the difference between fx55 and 3k+ run in memtest.
and I also will run full windows memtest.
bargain
http://www.overclockers.co.uk/acatalog/G_Skill.html
Price: £249.95 (£293.69 Including VAT at 17.5%)
bah, thats crazy, you could get like 4 gb's of UTT or 2 GB's of other TCCD for that price, somehow i think i'll give it a missQuote:
tsssssssssssz, here you go for 1st homework bro:D
CPU-Z verified:
http://valid.x86-secret.com/show_oc.php?id=14328
http://img19.echo.cx/img19/9742/ddr600ff32mpi6ho.jpg
I disabled either dynamic counter or bank interleaving (don't remember), that was so I can pass test 8, after that it could pass all tests as u can see in the last screenshot.Quote:
that's some amazing TCCD, 300mhz 2.5-3-3-6 @ only 2.6V :slobber:Quote:
btw can u get high memtest bandwidth numbers with any settings? or is it always no no matter what? my clawhammer 3500+ (which I assume would be similar) can get high numbers but it isn't stable at them, right now I'm using 310 official BIOS and it lowered the numbers at the same settings to ~2900 and it's fully stable at 300 x 8, but can't even boot at 2700 even though with some other BIOS I could reach 2800..
hmm, I think I'll give the BIOS you're using (414-1) a try again..
EDIT:I'm pretty sure that's OPB's work with his 0444MPM 3000+ ;) Well, at least we know where the screenie came from (lookclosely - right below "Written by Code Red.....") :D Hey Kev, ygpm commin....Quote:
