When will be available for download, Will it be a free download.
reading the thread is good you know, about 10 posts back it has the link.Quote:
Originally Posted by elec999
really nice, but you must change the pi with the "normal" one ;)
malachia whats wrong with the current pi calculation in your opinion?
is really different from the "normal" pi, if you use the normal one, a lot of people will use it!!! you can also only add a "link button", when you pess it the pi 1.4, pre installed togheter with SysTool, his window came up and you bench :DQuote:
Originally Posted by W1zzard
another good idea is to insert an uncheateble freq rilevetor(like cpu-z)
Wizzard, the monitoring software seems to be using mbm5. My voltages are way off compare to my multimeter. It be nice if you can borrow speedfan and use that instead :D
Your software programs must both read from the same parts of the motherboard, you must not have mbm configured correctly if it gives different readings than speedfan. Plus it is expected that rails will be off when read from software, thats nothing new.Quote:
Originally Posted by AKURA
I use speedfan because i get the same readings with my mm :fact:Quote:
Originally Posted by jumanji969
nice work
for example it isn't supported asus p5gd1 (my new mobo) i haven't really understood how to send a report 'bout it so i write it here :D
I copy that strongly :toast:Quote:
Originally Posted by Malachia
And MBM5 is the only prog I know that, when proper set up, reads everyeverything good, on every friggin mobo :)
the problem with superpi is that the sources are not available so it would be very hard to integrate
That's true. Open source benches should be really integrated in this. Any ideas when the final release is out?
Its good to hear this will be opensource, too bad mbm is gone.
Crud. :( How do I contact the person in order to get my motherboard supported?
huh? open source?
shadowing: i see you have aim .. contact me there.. i'm w2zzard
Can one decide what modules are
visible in the menu tree?
installed?
Just had a look, nice work so far :thumbsup:
Makings of a good all-in-one...
Gray
Nice :banana:Quote:
Build 136 (2005-04-26 19:28):
NVIDIA overclocking seems to be working finally
Added NVIDIA clock & temperature monitoring plugin
tested on NF7, seems nice :toast:
- cpu clock generator not supported yet :poke:
- temp HDD not shown, although not really important
Another reason for joining the dark side :p
Great app W1zzard.
Possible to add support for the Asus NCCH-DL mobo?
ICS952618/BF
W83791SD,
http://www.winbond.com/e-winbondhtm/....asp?Pname=749
These Asus mobos use the same ICS952618 aswell,
PC-DL
NCCH-DR
PCH-DL
PCH-DR
i'm still fighting with the ics95607 clock gen series of the ic7 .. once this code is working good, adding support for other clockgens should be easy
largon: an option to select visible tabs will be coming soon
Just put it out of its missery. LOL
could you please, try to support somoe notebooks with pentium m porc.
i have a dell inspiron 600m and would love to oc
here is the chipset and mobo info
http://img236.echo.cx/img236/2964/clipboard012ep.jpg
i could beta test it if you want
