So much for me being in Top10 :(
How about drawing a line after Top10 and extending it to Top20 ??? :D
More scores = more comparable info = less threads about "is my score any good" :toast:
Sweet score OPP and Hipro5 :thumbsup:
Gah - tryin like hell here...
15,4k reached in 03 so far... :) - Wanna get top10 again :P
05'll be no problem then... But thats lateron tonight... Lovely benching weather... - 10 degrees celcius outside earlier... - opened my window for 3 hours... Now I've opened the front of tha tower and taken out the two top 5,25" plates... And paced a room fan (dont know the right word...)... - It blows just against the downside of my radiator.. And upside... Then the two 120 mm fans transfers the cold air two the top through rad where the hard blowing air blows it away faaastly again... - This allows me to work with a 26 degrees celcius load temp on gfx and CPU :D
Guess the 05 score will be around 7250 once Im done ;)
It's something I have considered. It may possibley change to the top 15 or 20. If I decide to go ahead with it I'll cnage the thread title if possible and throw a post on. Hopefully get people who where up there to post again insstead of running through them all. As for me no benching till tomorrow :( Got the di container for my gpu done but found a small leak where I brazed in the mounting studs. Cheated and used some liquid weld. Hopefully be ready for tomorrow. :DQuote:
Originally Posted by bachus_anonym
Awesome man just plain awesome.Quote:
Originally Posted by OPPAINTER
I know this might sound sad, but i feel kind of prifilaged to be in the top ten lol.
My clocks are nice, just need to find me max cpu, and any tweaks for 05, as iam using none.
Are the 5.2 Cats best?
Im gonna stop benching for tonight... - Hit 7190 in 05...
My 03 I cant get passed 15397 :\..
The 05 however is only at 625 / 630 2720mhz...
Upping this to perhaps 2755mhz 630/635 tomorrow will up my score a bit ;)
Oh I knew Opp would post eventually. Awesome scores!! :)
Here's mine.
MSI K8N NEO2 Platinum, A64 3500+@2.7, Powercolor X800 Pro VIVO@16 pipes 658/637
7459
http://service.futuremark.com/compare?3dm05=638216
Damnit this is lame :P
I benched and reached 7211 marks... :) - Then two more reached high scores :( - Damnit :P - Then Im 11. again, hehe...
03 I just cant reach more than 15397 marks :\
Best regards
12k
BTW: any of you guess done pencil vgpu / igpu on a powercolor x850XT / XTPE ?
Thanks M8...... :toast:Quote:
I've got a lot of work to do, you know, BUT I'm prepairing my cascade too for some benching...... ;) :)
Yes very nice Hipro. Where do I start lookin for PS for my card? :stick:Quote:
Originally Posted by hipro5
#63
Would you mind testing 03 at 700/635mhz ?? :)
- 12k
geez come back a few days later, and I've been wiped off the list LOL
My scores are rubbish?:
http://service.futuremark.com/compare?2k3=3943409
How can i get this higher. Using 4.12 beta's. Is the CPU/ HTT really that important in 03? Can get it higher.
Also how do you guys only run the game tests? I see no option for anything like that, it runs the whole bench for me?
I believe 5.3 and 5.4's are best for 03 and 05. To run just the game tests wait until all game tests run. When the next screen comes up and starts loading hit the escape key. It will say not enough tests run. Close that box and up pops your score. ;)Quote:
Originally Posted by Grov
Thanks, ill try it next run!!!!
Yippie! I can finally publish with my Opteron 252! Been waiting over a month for this day...I'll be back with higher clocks soon!!!! :woot:
7115
http://service.futuremark.com/compare?3dm05=715302
New score, still not in the top 10, dam lol.
http://service.futuremark.com/compare?3dm05=827776
Moonman how do you get so high with those clocks? Ive got the same core, and higher memory, yet score 200 less. Using 5.2Cats.
All updated :D
@Grov Tweaking job ;)
Tell us some tweaks then man! :p:Quote:
Originally Posted by Moonman
