Can anyone get the 4 VDIMM jumpper to work with this P/S and a DFI NF4 MB?
I tried it yesterday and it will not power up with the 4 vdimm jumpper enabled :( Man i thought this prob was only with my zippy.
Eclypse - Ygpm :D:
EMC2,
Sorry if I missed it somewhere (I read through and couldnt see it) but does this PSU have the "split" design on the 24pin connector? Ie: does it detach into a 20pin and a 4pin if needed, or is it one solid block?
Thanks.
one solid block..
I'm about 90% sure i'm returning mine this tuesday.. Already put in for an RMA.
Seems to not beable to handle the load of the system and the 4 or 3 water pumps.
It will just shut off all the time.
So i've had to run 2 power supplies just to keep this thing runing.
I doubt this thing has 2 12v rails on the 8 pin connector since it is very unstable with 3 or even 2 pumps on that addaptor that PCPC made for me so i could hook the pumps up to a few extra molex connectors..
So.. I'd rather run 2 power supplies just to run the cooling then to pay $500+ for a supposivly 850-950WATT max P/S w/ another P/S.
I was thinking that this thing would solve my power issues but since its like 4 small 200 watt p/s's built together its not gona work.
Kinda dumb to have 1 12v rail @ 17 Amps power all the molex connectors and the motherboard..
I'm stickin to the 700 watt zippy..
Do you have a pic of the adapter they made? Or, can you describe the wiring of it? (the 8-pin has 4 black wires and 4 white wires)
Yup and it comes with a 4 pin addaptor to down convert it from the 8 pin.
The one the guy made me goes from the 8 pin to the 4 pin as well as use those extra unused 2 12v and 2 ground wires for the extra 4 molex lines. 2 connectors for each 12v line.. They dont share with the wires for the 4 pin connector.
I could take a pic of it soon enough since i'll be taking it out tomorrow sometime.
Thanks eclypse
Anyone tried this one in a Lian-LI 65??
You really need ~12" of clearance (length) for the PS... it's 9.5" long and that would leave a 2.5" area for air flow into the grill and for the cables to turn downward that come out of the back. (don't remember how much room is in a 65... fits in my 70 tho, no problem).
I guess it would fit in a Lian Li PC-76?Quote:
Originally Posted by Hombre
Don't guess, ask. :nono:Quote:
Originally Posted by sauria
Well, Daytona Dave. Does it fit? Tha case is larger than a PC-75.
Not me! Ask PC P&C and Lian Li, they will know. :toast:Quote:
Well, it fits just fine in my PC75B case. If that's any help....Quote:
Originally Posted by Dave in Daytona
Thanks LarsK. I wrote the company and they said that it will work in my PC-76.
"As long as the case is 20" or
more in depth (the PC-76 is 22") then it will fit."
Any pics of it installed in your case? I wonder how far back it sticks. Do you have a top blowhole?
Now we know young Dave ;)
what about a ufo? would this bad-boy fit in a ufo from mountainmods?
more in depth then it will fit."
Go look at the specs slicer
yeah, the ufo is only 18". it is an 18" cube.
krille and i over in the Liquid Cooling section were both thinking the same thing (will PCP&C 850SSI fit in a mountainmods case) So we both emailed them (as in mountainmods). The answer was that the PCP&C 850SSI will fit without any modifications in ALL mountainmods cases, the Twice7, U2UFO, AND U2UFO Optimax. For extreme watercooling applications they would recommend sticking the PCP&C 850SSI and the watercooling eqp in a U2UFO, NOT Optimax, Optimax is more designed for extreme aircooling. A tight fitting watercooling setup can fit in a Twice7 with the 850SSI.
good news for people who like cubes! :woot:
EDIT: not only that, but mountainmods got back to us within an hour of emailing them, now ain't that awesome? DOUBLE :woot: :woot:
EDIT: I just realized i didn't mention that you DO have to remove an HDD tray if you are going to use the 850SSI in a Twice7. The case is designed for those to be removable, and i'm sure we creative peoples here on XS can find a new place to squeeze it in ;)
