I know this is off topic and could probably be found with a little searching but I'm a little short on time atm so here goes...
What LDT and Chipset voltage are you guys getting the best OC results with? :)
ltd 1.4
chipset 1.7
[noob]
What's LTD or LDT (you each typed it different)?
[/noob]
They mean LDT, as in graphics card voltage.Quote:
Originally Posted by Psyche911
As I mentioned above: I would not trust Smartguardian!!Quote:
Originally Posted by Evil_Spork
I also have a problem. I can run CL2.5 again with the new bios but my GSkill LA won't do 300MHz 2.5-4-4-8. 290MHz at these timings is fine.
LDT voltage should be the voltage for HTT.Quote:
Originally Posted by UnreaL
Correct.Quote:
Originally Posted by phobos
doh......... ltd is a ford. lol i typed it wrong:)
--- MegaHurtz --- :slapass: :p:
--- phobos ---
Don't know what you have it set to now, but did you try upping VMem by 0.1 ??
Yeah, I tried Mem-Voltages from 2.6V to 2.9V. I think it's more a crappy mem comtroller than a memory issue.
I try to get a better chip cuz mine will only do 2.4GHz stable at 1.7V :(
Bummer on the 2.4 :( Heat issue perchance?
FYI... the newer TCCD likes 3.0V -> 3.1V ;)
:D Not always - got G.SKILL LA TCCD and the sweet spot is at 2,7 Vdimm.Quote:
Originally Posted by EMC2
:toast:
I just flashed to this BIOS after having problems running dividers with my high clocking BH-5s and it's the shiz...I was able to get into Windows at 270 and run any divider. Great stuffs.
so the new 310 helped you clock your bh-5 up?Quote:
Originally Posted by caboob
for me, bh-5 oc'ability stayed the same at 3.4v, but running dividers is def. better in this bios. im on beta.
very nice. im on bh-6 and i can only get like 257mhz stable with a divider with 2-2-2-7 1T 3.6v so maybe this bios will help me out a bit?Quote:
Originally Posted by pershoot
True that, not always (for anything) :p:Quote:
Originally Posted by HARDCORECLOCKER
But a lot of the highest clocks on it are in that range, look at OPB and Bachus screenies ;)
:toast:
drop to cl1.5 and test your mileage also. if you cant get high FSB, go for ultra low latency:) surprisingly, cl1.5 is more stable then cl2 is for me. i cant use cl2 for some reason past a certain mark. it throws up errors here and there. thats the wierdness in the winnie i s'pose, hehe. 10x also doesnt work well for me, but thats another story, ha.Quote:
Originally Posted by stealth17
im limited to ~250-251 by memtest standards (1 1/2+ pass #5), 1.5-2-2 (i need tRP, tRRD, and tRTW to 3 for prime) with 3.4v. havent tested higher vdimm.
alright ill do that tommarow...the only timings i have tried is 2-2-2-7-1t, 2-2-2-7-2t, and 2-3-3-7-1t....they all seem to give me about the same results mhz wise...Quote:
ill try that 1.5 thingy...never done that one..thanks :)
give your ram about 3.5 or 3.6v. you will be much happier trust me!
get off tRAS 7 also. from what ive experienced with my ram and mem ctrlr, tRAS 5 works the best. past that is instability. tRCD of 3 doesnt work too well either for me.
New bios is working great for me.Quote:
Vapochill LS
seems stable so far at 12.5 x260 HT 4X
My mem bandwidth is down from 8mb to 7600
weird
all my ram timmings are on auto when i cleared the cmos
No, but it allowed me to use the dividers without crapping the hard drive like the previous BIOS installed.Quote:
Originally Posted by Unrealcpu
your on a divider at .5. what was your last OC on the memory?
What are u running under the Vapo?Quote:
Care to update your sig or add the AMD portion to it.
Still looking for successfull winchester under phase and DFI Nf4, any good news? (sorry for OT)
Hmm, my write speed under everest is horrible!!! :(Quote:
