Hotter is a result of more voltage so we don't intend on making it hotter but we know what the end result is because of higher voltage. Just as you apply higher vcore, you know the the cpu will get hotter and also produce more mhz to a point where the heat can't be dissipated. That is why we buy bigger and better HSF, water cooling and chilling units. If you can remove the heat, you will be able to extract more performance. It is proven all over the place.Quote:
Originally posted by Dissolved
Why would you need to run it hotter for? i don't know that much about the chipset in boards, but more voltage=more heat. So Enless its been proven (which it hasn't)
Close!:D No, not so much that it will suck a*s, but it will not measure up to the hype that pre-lead it!Quote:
Are you trying to say The NF2 Will suck ass?
