Originally Posted by the_countess
SUCCES!!!
with all 3 set to exectly 20K i get these voltaged
VGPU 1.87v VDD 2.18v VDDQ 2.18v
default for VDD and VDDQ was 2.1 but i forgot the measure to default voltage for the core. (anybody know the default?)
still @ stock cooling (watercooling on the way) so im still gona be pretty conservative with VGPU for the moment but i'll see how high i can clock it now.
*edit temps when ever 90C with these voltages, normaly they'd stay at almost exectly 60C under full load.
so if you want to stay with stock cooling i'd recommened putting a extra 5k ohm in for the VGPU or something.
as for max voltages.
that totatly depends on your cooling, your nerves and your modules. hard to say really.
keep a eye(or finger really) on the modules temperature, make sure its not baking.
then make sure the modules can handle the voltage.
set voltage too high and some modules could start making mistakes even on default speeds.
just increase slowly step by step and keep testing using ATItool for example.
VDDQ is the input/output voltage of the memory system. so VDD controles voltage inside the modules and VDDQ is the voltage for outside communication. they should be and stay pretty simular with VDDQ never exeding VDD.
