I will try force flash in the morning.
I WILL send to you chew tomorrow.
Another ABIT K8 board without multi. adjustments on the initial BIOS. I wonder if it's hard to get it right.
I'm happy to read the Vcore is stable on this board... I'm not an extreme OCer but I care about that sort of thing.
Oddly i cant flash it in windows ill try force flashing in dos tommorrow. Gave a wrong part # error but i believe its more of a protection versus a security feature just keeps you from flashing the wrong bios to your board thats all. If this is the HIGH securtiy everyones talked about it should be simple to get around. Not to hard to edit the bioses part #.
What's the difference between the two bios'?
i think either ABIT hasnt enable that 2 features DDR&CPU Refvolt or they forgot to test it :slap:
well one thing we know from screenies is that an8 vanilla dont have 1.85 vcore option.Quote:
Originally Posted by Gitsum
I'm not so sure about that now tic tac i cant open it with modbin. however it opens fine with awdbedit. kinda odd. I'm kinda working on the k8ns ultra 939 bios right now so I really don't have to much time to fool around with this one yet(k8ns ultra bios kinda sux when overclocking bios options tend to just dissapear :( )Quote:
Originally Posted by tictac
You'll definitely have to change this tic tac. it's so blah. your logo screen looked so much better for nf7-s.
http://members.cox.net/italygirl25/abit.bmp Yes i just temporarily used it as my desktop to show it No Im not keeping it lol
HAHAHHHAHAAHA good one chew.
Ok got the day off from work, so about to do some more testing.
Firstly the board hates my tccd memory.
It refuses to run with my gig of twinmoss.
Everytime you switch out mem sticks you must clear the cmos.
I have a x800pro pcie card about to run some benchies.
AFAIK wasnt Abit supposed to impliment an overclocking BIOS that you had to DL from them <thus voiding your warrenty> I had head of such talks on OCforums, perhaps this explains it.
As for the boot screeen my AV8 does the same thing and I agree it looks like crap when you compare it to Epox and MSI.
Does anybody have this board at home ? Why you dont test it properly ? You still talk about bull:banana::banana::banana::banana:s. Write something about OC, voltages stability, mem supprots ... etc. I cant express, what i really want .. becouse my english is not very well :stick:
Read the thread from the beginning, I have given the voltages, stablity, and what it will oc to so far.Quote:
Originally Posted by dymONE
Just got back, will esume tests shortly.
Got a 3000+ will see what i can do.
also picked up some twinmoss speed premium and got the ati silencer on the x800pro.
hummm !!!!
two fatal1tys .... and the two don´t like tccd, thats to bad.
bh5 do not solver the problem, the volt... don't make it higer :dammit:
you still cant flash your bios ????
hug'z
The AN8 was tested with a Winchester (1.4V default) and the Fatality with a NC (1.50V). I think it's very likely the max vcore depends on the CPU default.Quote:
Originally Posted by chew*
Um one board doesnt like tccd as far as we know. No one has tested with bh5 yet....... We do know that ddr booster does not work at this time on an8 as to why not sure yet lets wait to see what OCZ says on that maybe a newer bios will work. As far as the bios goes its a backed up bios file from the fatality rom and does not belong to the an8 vanilla so it may take a mod to the bios to allow it to work. We really wont know till we actually get a AN8 bios and fatality AN8 bios from abit itself.Quote:
Originally Posted by ...:::MadDog:::
Your absolutely right, I stand corrected. I will update that when i have confirmation from gitzum when he gets the 90nm 3500+. The good news is if this is the case and we know the board has the option we might be able to mod the bios to give winchester voltage options.Quote:
Originally Posted by thebluesgnr
Whats code 83 In your manual and did you try this just a hunch maybe.Quote:
Originally Posted by althes
try it with one stick of memory with the booster in the same dual channel slot.I'm curious if its actually seeing it as a stick of memory in the slot. If it is nforce 939 boards dont support or work with 3 dimms installed its either 1,2 or 4.
what will happen when they throw FX55 on this board?
might unhidden extra voltage as well... ?
If that is the case... what will happen if they throw in RAM with 3.3V default voltage
:hehe:
i ask OCZ about DDR Booster compitablity with AN8 Fatal1tyQuote:
this is what they said... :confused:
Originally Posted by RyderOCZ
Hum... would it work if you use a 20-pin PSU?
I am using a 20 pin psu antec 480w and it wont work.
No go on the booster, which really sucks.
Tried yesterday, using chew suggestion.
I got it to intially work, it said 2.8v same in thebios.
Then after I rebooted and tried to up volts the booster stayed at 2.8 regardless.
After that it just stopped working and gave me code 83. Which is save all data in bios back to stack.
Just started testing with some hyperx 3200 bh5.
You cannot use dimm3 and 4.
The computer will not boot.
You must use slots 1 and 2.
Running some benches at stock brb.
We are waiting for the results. :banana4:Quote:
I want to upgrade my nforce2 to nforce4 (DFI or Abit) soon, and want to use my Kingston HyperX PC3000 (BH-5) 2x512MB modules.
