On nVidia the rule of thumb over the years is between 3 and 4:)
Randi:D
Randi:D
my score with 71.25whql
best regards
mr.icee and zakelwe
http://img230.exs.cx/img230/601/0126jz.png
http://img192.exs.cx/img192/8779/0328ud.png
http://img192.exs.cx/img192/9681/0517dy.png
luigi
6600gt at 1.68-1.7v
Hm, those PCI-E cards are a tad better than my stock AGP XFX-6600GT version
Rig, Intel preskot at 4.16Ghz, 1:1 cpu/ram ratio.
Aquamark: 68.4k
3dmark2003: 10.3k
3dmark2005: 4.1k
on water (maze4 block), no vmods @ 652/1.23 :) ,(at 658) can't finish the benches.
Seems that the FX-55 has an advantage at all of the scores you guys get in contrast with an Intel rig ;)
B
Wow, nice gigi77 :toast:
Not as spectacular as Mr.Icee, though more appropriate for those mortals without OC-loveable cards :D
I'm comming guys! Just a few runs done. I will Vmod it and tweak to the max this week-end;).
http://service.futuremark.com/compare?2k3=3721040
its so booring over here, here i am trying to compete with your scores with stock cooler because the lousy heatsink didnt fit :mad:Quote:
Originally Posted by skate2snow
i'm joining the race too :)
Funny 6600GT :D
Is there any Ovp for those thing ?
Passive Gigabyte 6600GT with enermax 80mm on both sides.
http://service.futuremark.com/compare?3dm05=601753
thanks!Quote:
Originally Posted by Juliette
luigi
Nice core clock on the GT Luigi, seems to like the voltages, what cooling have you got on it ?
Regards
Andy
Nice score as well s2s :toast:Quote:
Regards
Andy
Another nice score as well .. the 6600GT is rocking at the moment :DQuote:
Originally Posted by misteroadster
Mines back on my reserve rig tonight ( Newcastle 2800+ 2600Mhz 290x9 5:6 2.5-3-3-7 Cru ballistix all air cooled ) to see what it can do on 05 with cold air in europe tonight.
The card seems to work fine with 1.75v tonight so that is good news, normally it throttles above 1.65.
The AGP bridge chip gets very hot though,
Regards
Andy
http://service.futuremark.com/compare?2k3=3721962
I'm running to catch ya guys;). No Vmods... I will get 11K w/o Vmod, and after that I will Vmod...
what 6600gt?Quote:
What you think;). Yes.
BTW: Got my 11K.... Now I'm going to Vmod it up to 1.75V for a few Benchs. http://service.futuremark.com/compare?2k3=3722027
very nice but what brand and what temps?Quote:
S2S - Asus?
read in his link, gigabyte :)Quote:
I dont know about the temps, but before that it hits the CPU the water is at -25C, and the CPU is at -13C.... And I'm in serie...
Its a Gigabyte...
very nice!Quote:
so it seems that the 6600 like the cold thats good :p
edit: what temp does the drivers report?
edit2: whats the diffrents with the gigabytes 6600gt (D) and 6600gt (VP)?
edit3: how did you mount your cooling?
when im trying to mount the cooling the hole card starts to twist so how do you mount it? pls help me
Under 0C the driver does not support the option to see the temps.
I dont know the difference.... It might be minor....
I'm using the stock Maze4 mounting..... So I cant help more then that:|.
As reported here 2 weeks agoQuote:
Originally Posted by Snowman89
http://www.xtremesystems.org/forums/...ad.php?t=52549
"I've never in my life had to change the gpu MHz and gpu core voltage so much on a chip within a run to stop it getting too hot .. stupid 0.11 micron process without low k, this does not bode well for overclocking the X800XL unless cooled with water or phase"
It's the cheapy 110nm TSMC process without low k dielectrics so course it loves the low C to compensate.
By the way. my green triangles are getting worse in 05 :D
Regards
Andy
Oh, did I forgot to say I dont have a single artifact in 03?
Be very careful on your voltages on these, they will smoke very easily:)
Randi:D
Randi, I dont go higher then 1.75V.... You think it is dangerous under 0C? I think that for a few benches it is safe.
I found a way to softly change the voltage as you want. I will post about it later;).
http://service.futuremark.com/compare?3dm05=603623
it seems the DFI is powerfull or miss me some tweaks :D
No LOD bias.
