NV overclocking isnt scientific b/c you can set mhz by mhz, which isnt accurate at all. ATI overclocking tools "show" you precisely what clocks you are setting, NV doesnt.Quote:
Originally Posted by eva2000
The other way this happens (happens to me at max clocks) is when I set my core to 515 or 516, it will only run at 513. I've confirmed this with rivatuner monitoring and ORB scores. So even if I push a little higher than 513, it wont actually drive that higher frequency.
Not sure which one is happening for you, probably that setting 455 is actually closer to 453, can you try 456 and see what the orb tells you, or riva monitoring? Hope that helped.
