still, i think many ppl are waiting for those 1gig kits ...
can ya at least say - weeks/months ?
can you actually get those PC4800 in a 2x256 Dual Kit yet? Does it really matter if they come in a kit? It looks like 2x256MB are not in retail channels yet - Digi4me and Newegg don't have them yet but they have sinle 256MB sticks....
Do you have any info on availability of those 2x256MB kits in US ?
EDIT: i had to edit that post for clarity :)
is that what you r looking for ?
http://www.newegg.com/app/ViewProduc...231-007&depa=0
check the pics - it's saying pc4800 ...
thanx S&M - that lack of "PC4800" in a description made me slightly confused.... thanx
I want to be able to buy atleast two 512MB sticks separately even if buying them in a kit will be far off. Although I imagine the availability of both of those items are intertwined. Can we have a date no matter bewildering it may be OPB? Weeks, Months, 2006?
np at all - that's make us two confused ppl ...
I was wondering about 'em a lot .... till I bothered to check the pics ...
Actually , the PC4800 LA 1G kit is rated as DDR600 "2T". That's why I always recommand LE;)
I ended up ordering a gig of LC (the bloody day before LE and LA became available)Quote:
What can I expect to get from it on an MSI K8N neo2 and an FX-55 and at what voltage?
Sorry for the O/T question, I'm just worried that I've picked the runt of the litter :(
Originally Posted by GazC
LC is like DDR550 2.5-4-4-8
I had that experience run it like DDR575 2.5-4-3-6 on Neo2 fx55
BUT, be sure you got good power and good neo2.
OPB
I always make the wrong choice, I was hoping to have got into the 280s with 2.5-3-3-7. I have a PCP&C510 so I have a good power source. It's typical that the store would have LE and LA available after I order.
What is the best voltage for getting high clocks with LC anyway?
It depends, I would say if you wanna run 280 for sure, I would give around 2.8 but I am not sure ! Some of my friends they show me like 2,7 for doing DDR570 passing memtest std mode for 3 hours
You gotta try!
PM me after you got the ram and question stuff.
OPB
okay, thanks.Quote:
??? LA is the best choice ? :slobber: U recommend LE but U do better with LA ?
do close to 9k5 need cascade ? Thx
:slobber: very nice , makes me want to cry
whats better for gaming....high bandwidth or tight timings?
I checked Gskill global site, I don't see PC4800 1GBLE ?Quote:
Only pc4800 1 GBLA and 1GBLB
I have a set of PC4800 1GBLA and the shop I ordered from told me they were supposed to do ddr600 @ 1T :confused:
oh, and congratz on your world record, truly amazing :toast:
not that I'd expect anything less from ya :p
Dear Kristos:Quote:
Originally Posted by kristos
There is some misunderstanding here !
LE means DDR550 2.5-3-3-7
There is no LE with PC4800
LA 1gb only good for 2t DDR600
But I tell you what, my experience on NF4, I can easily do DDR600 "1t" with LE 1g kit
If you have futher question need help, please PM me, I am more than happy to help you!;)
i sent you a pm yesterday OPB about a gig kit of LE. just wanted to know if my results were normal.
how many sticks of ram did you go through before you found the kit that got that bandwidth? :toast:
Originally Posted by Skip
I only have 1 LA kit :)
OPB
sheesh, i thought you got lucky with an LA kit, that LA must be some good stuff. Should probably pick up some of that for when i get my waterchiller finished.
Those are great results OPB! I've got 2x256 LE and I can't get over 250 2.5-3-3-7 on my Neo2 + FX-55 combo... which is strange cause I can hit 300 2.5-4-4-8 with them :( What am I doing wrong!?!?
I second that too, what's best anyway? I really need to know too, before jumping in the wagon...Quote:
Originally Posted by Playful_Buffalo
do you mean high unbuffered bandwidth or high buffered bandwidth?
@stevil
wichever be best for gaming
@OPB
it's always a pleasure to read your threads
http://www.xtremesystems.org/forums/...ad.php?t=48634 Check that thread out. from looking at that I would be inclined to say that speed is greater than latency when it comes to gaming. The latency frequently only seems to have a marginal effect, which when benching or something might be make or break, but for regular everyday usage would be almost un-noticable. I dont know if he has done the frequency comparo at different timings yet (seems it hasn't been bumped in a while), but from my experience (but no set in stone test #'s) mem frequency seems to have a nice bump in performance. I guess I'm saying that, while I dont know 100% for sure, frequency would be my guess but wait on one of these guys that does know before going one way or the other.
