the link is dead, can some1 upload it again? thank you
*bump* :)
Here is 1.5 Mod
The old 1.5x isn't online anymore.
wat are the changes? i need to feed my amd up to 1.71 voltage to get it stable. is the voltage selction percentage can select up to +18 % ? thank you by the way
Thanks...will test the 1.5mod! Btw, just found the 1.5x Mod archived on one of my cd-r discs...so i'll compare the two. :)
1.5 mod is the modded version of 1.5 offical BIOS. 1.5x is a beta version.
all hidden options are selectable. For example the speed of the chpset fan.
Maybe a mod of 1.6 offical follows.
@david
no, the only bios with 18& is the 1.36mod
Hmmm...well my board now refuses to boot at over 300HTT; a bit worrying considering it would boot at 340 previously! Maybe all this bios flashing (through windows) has messed my board up. :(
There's an already a mod for 1.6 out, but i've lost the link for it! The official 1.6 is not that good however.
ok, search for it. I've swapped to DFI NF4 several weeks ago. If I'll mod 1.6 it will be an untested version. The 1.5 is the last version I've used on the MSI.
Yeh, i've already tried the 1.6mod...it fixes the temp issues etc with the official 1.6 and seems quite stable too. Along with the 1.5x Mod (which ive just tested), the 1.6mod seems the most stable bios for me so far. :)
Whatever you did to that 1.5x bios works a treat! :thumbsup: What did you use to mod the MSI files?
EDIT: still can't get it to boot as high as before, even with a flash using Awdflash / floppy! Guess it wouldn't be as addictive if there wasn't the odd problem to sort out :D
Well it's no big deal. Just load it into modbin and unhide the hidden bios menu items. Very easy to do.
With the DFI there's no need to do so. All options needed are in normal bios already. If you're searching for a new one it's the first choice.
Hmmm....yeh that's what i've done with bioses in the past...just the modded version from you seems to work better than the original 1.5x so i thought you might have tweaked something else - must just be a quirk!
