oh lol ok :D
oh lol ok :D
any unpatched superpi 1m?
zabomb4163
Probably + 2 sec.
:confused: :confused: IF you take a look at the begining of my thread and the screenshots , you'll see BOTH of Super-Pi 1M - UNPATCHED and PATCHED........Quote:
Originally Posted by zabomb4163
Hi!
These are some nice results...but I guess the DFI is the better board.
I just reproduced your results with a completely unmodded LP875P-T and stock LS Rev2. I will post some links later. 32M patched took 21:23 with 4937MHz. 32M unpatched is running atm at same speed.
Did you use 5:4 and 2-2-2-5? I'm running 1:1 with 2.5-3-3-8 and I needed some mhz more for 26s (5025MHz)...I should get my BH5 in again ;)
I guess I can't do much more than that...but it's impressive enough for a 3.6 D0
very nice, the DDR optimizer seems to do its job good ;)
Thx again for the inspiration ;)
1M Unpatched
http://www.forumdeluxx.de/gallery/da...4491munpat.JPG
1M Patched
http://www.forumdeluxx.de/gallery/da.../94491mpat.JPG
32M Unpatched
http://www.forumdeluxx.de/gallery/da...4932munpat.JPG
32M Patched
http://www.forumdeluxx.de/gallery/da...944932mpat.JPG
yeah sky :banana4:
Yes I was running at 5:4 and 2-5-2-2....... :)Quote:
Originally Posted by xsky
FPO/BATCH for this CPU?...... :D
Happy to see ppl with Intel going high......... :D
Almost 60MHz on RAM speed to "match" the 2-5-2-2 BH-6/5 chips.......BH-6/5 WILL NEVER DIE...... :D
Best will be a 3.8GHz CPU at 1:1 with 2-5-2-2......... ;) :)
L434A843 SL7J9
I've got some nice BH5 here but 875P-T doesn't like 5:4 that much
There is an issue with 5:4 divider on this board.
yes. 5:4 gives me much lesser oc :(
I tried a little more:
I could run 1M at 5045MHz.
Right now it's running 32M at 4956MHz and is still looping.
It almost seems as if the board was holding me back...only 90MHz or less difference between 1M and 32M at same voltages etc. is strange, right?
Nice stuff guys AMD a64 is about 3420mhz for 24s whats intel take nonpatched for that?
Also any 3dmark 2001 benches so we can check out system scores?
Thanks and nice work. :)
my NV40 is still in RMA...3DMark with FX5200 won't be too much fun :D
lol nope It won't :)
HiPro5, your birthday present was quite welcome ;)
Vagp, VFSB and Vchip mods gained almost 15MHz with 1:1 divider and tightest possible GAT settings :D
What values are the most optimal, for Vfsb and Vchip?
I have set both voltages to 1.7V (measure in bios).
WOW, just want to know if you try and leave it for 24 hour to see if it's stable.
No matter what leave the Vfsb at 1.35 - 1.40Volts at 5:4 and almost the same at 1:1......At 3:2 you have to push it a little bit higher at 1.60Volts......VAGP leave it at MAX 1.95Volts......Vchip you can start from 1.52Volts for 5:4 and 1:1 and at 1.9Volts at 3:2.......It doesn't help the 1:1 or 5:4 a lot after 1.55Vchip....... ;)Quote:
Originally Posted by The Stilt
..........and HAPPY THE NEW YEAR to all of us..... :D :toast:
On 2001 Prescotts give shi(f)t compared to my P4 3.4EE one.....A P4 3.4EE @ 4500MHz is a LOT BETTER than my P4 3.6E @ 5000MHz.....NO GO on 2001Quote:
Originally Posted by choseone214
On the other hand at 2005 are about the same BUT P4 3.4EE@4500 = P4 3.6E@5000
At 2003 the P4 3.4EE@4500MHz does better from the P4 3.6E@5000....... ;)
As a matter of fact I've leaved it crunching SETI about 3 days straight @ 75 WU+ but I just COULDN'T stand that noise any more....... :DQuote:
Originally Posted by XyKo
yup prescotts seem to sux at 3d2k1 only just managed to break 30kQuote:
Originally Posted by hipro5
Powercolor X800XT PE stock cooling @609/603 - 3Dmark2001 = 30,004
just stopping by to say "good job" =)...not that you need another "pat on the back" but you deserve....
now, a bit OT, where's that DDR Maximizer of yours ;) ?.....anyone here at Xs to test drive it out?
very impressive once again hi pro.
As always Hipro5 – state of the art! :toast:
Btw: I’m looking forward to my delayed Christmas present ;)
how come you wont show us the PCB slot for the maximizer hipro? i noticed you didnt include it in the pics and its not in your maximizer thread either.
and care to explain what you did to that BH-6? (IE how you figured out where to solder the caps and what resistance you used and how you knew?)
