It's only $10 cheaper on newegg. $130 shipped was the best deal I could find on this board through pricewatch.Quote:
Hmm, i figured the price difference was similar to what it is in Australia. Here the 9NDA3+ is ~AUD$240 and the Neo2 Plat is ~AUD$290...Quote:
Originally Posted by JDizzle
Ah, super! will flash tonight :up:Quote:
Originally Posted by SmokeyTheBandit
Frequently easier to reach than neo2 to have + 300 outsides of 9nda3Quote:
Originally Posted by Jeager
Just operated the computer and ran 1.6V run 2.7G while being steady while being about Use the same CPU with RAM before this Is it get 1.7V is unable to let P95 run two PASSs to add at NEO2
http://hkp2p.shopping7.org/~hardware...9NDA3/2700.jpg
But the network is really unstable, but the little younger brother has already touched too much unstable problems of NV board network from NF2 to now So I have already prepared 3COM, the network card is very cheap
Max Vddr is 2.8 :confused:
Just so Im sure on this; was the problem with dimm slots 1 and 2 fixed after you flashed the BETA BIOS?Quote:
what new with the beta bios need some infor
Nope problem is still there .... :mad:Quote:
ok have anyone try it with 4x256 memory. like me. right now i have it a 9x260 and the memory is at FSB 216(166) i know i can get more out of it but do not know what is hold me back can any one help
also can anyone tell me do i have to set agp 67 or can i set it at 66
It seems so...:SQuote:
If they don't fix this it will be a major negative point against this motherboard and the MSI will continue to be best socket 939 board.
Btw, the problem with the OCZ Booster it's only because of the voltage increase or the booster is incompatible at all for other reasons?
im wondering the same thing altho the vmod dosnt seem that hard to do but i would like to find a way of doing it with out pernatly vmodding the boardQuote:
Originally Posted by dutchman.pt
to esoteradactyl:
Want BIOS diagram CPU voltage, preserves and adds 0.5V, it is that 1.45V take-offs to be basic http://hkp2p.shopping7.org/~hardware/TEST/9NDA3/B1.JPG
Time have frequently, have 8 lower frequently most, 3000+ is 200X9, so there is 8& 9 but choices The same, 3200+ is 80 but the choice, the elasticity is not great enough http://hkp2p.shopping7.org/~hardware/TEST/9NDA3/B2.JPG
RAM voltage, 2.5~2.8V, TCCD is set as 2.7V in advance with AUTO, it will be better that there is above 2.8V
http://hkp2p.shopping7.org/~hardware/TEST/9NDA3/B3.JPG
NF3 chip's group's voltage, 1.6V is preserved, can pressurize , this is a advantage
http://hkp2p.shopping7.org/~hardware/TEST/9NDA3/B4.JPG
Parameter of RAM
http://hkp2p.shopping7.org/~hardware/TEST/9NDA3/B5.JPG
It is here to establish CPU adds 0.2V RAM 2.8V Chip 1.65V Voltage that the host computer board examines out actually
http://hkp2p.shopping7.org/~hardware/TEST/9NDA3/B6.JPG
11/25 BETA BIOS behavior that esoteradactyl offers is still good Original part that DIMM3&4 can't start the machine (whether have meet by net friend can run 4 3&, 2 1& not all right) Can go to DDR600 about one pair of passways now, it is still a bit weaker than 1& 2 on my board Basically test this host computer board unless it get here of, can come report more for new discovery:)
so a vcore of approximately 1.6v is max. available ? ;(
The bios is quite cool for ocer , unlike the Neo2 does :(
What i understood of the problem is that if you raise the vdimm above 2.8v it will fry a mosfet and kill the board.Quote:
Originally Posted by confuzzedintel
Now if it is OCZ DDR Booster + Epox fault or it's only fault of one of them i don't know.
If someone could clarify us that...
i dont think the booster works on any board that draws the vdimm from the 5v rail.Quote:
In that case if you raise the 5v rail you raise the Vdimm, right ?Quote:
Originally Posted by esoteradactyl
With the OCZ powestream that would be very easy but we don't know if the mosfet also melts in that case.
Btw, can someone give me a link to see or tell the usage of the PSU rails for the different hardware ?
The Question is, if this only can happen with the DDR Booster, or also with the vdimm mod.Quote:
Bigtoe, how much Volts can you give with your mod? I have also read, that vdimm above 1,7V can be unstable on this board. Have you realized any Problems?
Still not sure which Board to buy... :confused:
That's exactly what i said. :)Quote:
Originally Posted by Riemen
no that is not how it works. there is a voltage regulator limiting the amount of voltage allowed through it. by moding it, you will be lowering the resistance thus allowing for more voltage. so raising the 5v line will do nothing unless you mode the voltage regulator. if you were to mode the regulator there would be no reason to raise your 5v line since you would already have 5v available.Quote:
however if you were modding the 3.3v then you would increase the rail in order to raise the voltage above 3.3v. obviously that isnt an option on this board, but it is on alot of others.
Thanks for the explanation.Quote:
I was applying the same logical method that you explained for the 3.3v. :)
But the board can reach higher vdimms (with mod) without the mosfet melting or not?
Is the chip capable of setting higher voltages 2.8v+ with a modded BIOS? Is the BIOS mod-able in regard to vdimm, for that matter?
in order to use the 3.3v method you would still need to mod the board the same way i explained how the 5v method works. the dfi 250gb is the only board ive ever seen that would allow you to just raise the 3.3v without physically modding the board, but this was used with a special bios.Quote:
you dont need to be worry about frying anything as long as you have good airflow surrounding the board.
i checked the bios with modbin to see if any additional voltage options were available and didnt find anything :( a modded bios might work but it all depends on the type of volt regs they used on the board.Quote:
it was interesting though because there were two different listings for the vcore. one had vcore at +0.20v and the other had +0.35v. i have no clue if those options can be used or not. the option to make them selectable in the bios is not there. here are some pics that show my findings. i know bigtoe is good with bioses so maybe he can lend us some of his knowledge :)
That first list is great... vcore selectable from +0.025v to +0.35v in 0.025 increments!!! That is exactly what I have been hoping for vcore wise... nice one esoteradactyl.
Just to confirm what you said earlier; that the 9NDA dimm slots are fed by the 5.0v rail? Now, if to find a way of getting vdimm selectable up to ~4.0v.
