Is it possible to use instead of the 47 kOhm Trimmer a 50KOhm Trimmer?
vagp mod; may I hv some better photos and resistor value pls ?
tks
These are nice pictures and some good info, but are there more comprehensive instructions... Like Parts list in particular... I see a lot of refereces to 50k trimmers, but will any do? Whats the recomended amountof turns on the adjustment? Wattage rating?
Thanks...
The Vdroop mod needs approx 28K Ohms to function correctly, You will use a Multimeter to pre-set the Variable resistor (trimmer)....then solder in place as shown.
C
Is this a GOod trimmer to use then?
http://www.alliedelec.com/cart/Produ...299P%2D1%2D503
BumP?Quote:
Originally Posted by DDA
Does anyone have better detail of the Vagp mod?? Resistor value??
C
or maybe a VTT mod??
Found this from my archives:
http://www.akiba-pc.com/P5P800/VAGP.jpg
Asus boards don“t need VTT mod, because its tracked perfectly by default.
Just to add, you can use pin 11 of LM324 for GND if you want.
which pin is 11? I always get confused where to start when counting pins :D
can you mark up the pic?
C
Pin right above letter "A" of the IC marking.;)Quote:
Originally Posted by charlie
thx, Malves!!!
I might have missed it somewhere, but does this board track VTT correctly? In other words, will I be ok if I just use the direct 3.3v vdimm mod? I don't think I'll do any other mods. My A7N8X is dead because of my crummy soldering, but this looks do-able.
-Collin-
Yes, VTT tracks vdimm.
Anybody have any insight into the fsb instability above 260?
Is it real or a measurement glitch?
Any fixes out there?
Gnode
could the vagp damage the videocard ? :confused:
No,Vagp does not have anything to do with the AGP slot. Increasing vagp, may improve stability on high FSB.Quote:
Originally Posted by Supertim0r
Instability at high FSB ---- Solution!!
Update: Solution -- Used a 20 pin to 24 pin adapter for the atx power supply
Rock steady at a FSB of 270 MHz -- Thanks, I Found NEMO
Now at 280 MHz!!! :woot:
Originally Posted by gnode
Unfortunately now Instability sets in at 284.
Help anybody?
where can I probe with multimeter, for vcore droop?
So can i use a 28K fixed resistor or should i use a VR to find exactly where it should be?
And how do i know when its where it needs to be?
I've never done any vmods before and i don't want it to fry.
Does anyone make a particular tutorial to help with us?thx
Here is one i drew up for the droop mod.........
http://forum.overhauledpc.com/showth...=9267#post9267
-CaT
Hrmm...it shouldnt damage your agp card, it may heat it up a bit more, as it DOES increase the voltage to the AGP slot, it also raises the NB voltage a bit which is why it can help stability ;)Quote:
Originally Posted by Malves
-CaT
Any reason you couldn't use grabbers on the legs of the chip?
