ive asked them. i joined pcperspective forums just to ask the abit PR. no response yet. also ive asked several modders for a modded kv8 pro bios but no luck.
my ocguru doesnt work so ill be the first to try the vdimm.
I've heard that on most mobo's the older version of uguru works, may try it and see if it works :)Quote:
One question i've on that one, since the uguru is a windows software, when you change the vdimm to 3.2 and restart... do you have to reset it back to 3.2v again???Quote:
Originally posted by htkm1
The uGuru that came with the installation CD is able to adjust the VDimm to 3.2v. But the problem is that the VTT only follows up to 2.8v. anything above it will not follow.
Or it keeps the setting on the bios and each time you boot the Vdimm stays at 3.2v ?
Cheers,
B
Wierd, the mod worked fine for reject, try resoldering the connection.Quote:
tried it. does not work! :(
-CaT
becuase its so small it may take a few tries to get it not shorting over r19. what i mean, is that its so small, there may be the slightest cotsct between each wire on the pads and that mean the mod wont work. just keep trying took me a few goes. just try not to burn the mosfet then ure fkd
byron: i tried the old one from the install cd but no luck. just got crashes wheh i tried to apply the profile. luckily only the program crashed
:( Hopefully or they'll come up with a new bios with up to 3.2vdimm or someone will mod the bios in the near future... because that mobo have some good potential i guess with more vdimm :cool:
yeh, especialyy for adata vitesta. 295 fsb has been reached on some p4 board with these sticks at 3.4v
could someone please post a picture on teh soldering spots and an explanation on what would be on each place?
of the Vtt mod? "what would be on each place"??? :confused:Quote:
Originally Posted by Snowman89
heh, yeah, im not so very in vmodding so :rolleyes:Quote:
Originally Posted by Goldlocke
Hello!Quote:
Originally Posted by Byron
The easiest way to set higher than 2.8V Vdimm on KV8Pro:
1. Save your current BIOS to file.
2. Load BIOS ver. 1.1 or 1.0 (which have up to 3.2V settings).
3. Set your favored voltage for DIMMs with 1.1 BIOS.
4. Load saved BIOS.
5. Don't change Vdimm in BIOS - You will have old setting for it's next change.
Simply to do and works fine...
How you know that after all this procedure the Vdimm is at 3.2 ??? Did you measured it from the ic?
I have 3RD Eye and it shows it (the same shows AbitEQ). In newer BIOSes after that 'trick' You will see that there are options for voltage who are blanked and BIOS 'don't know what is going now'.
Try and see it by Youself.
Abit engeeners locked over 2.8 Vdimm because over VTT is going down seriously and it isn't half of VDD (for 3.0V is 1.36V, for 3.2V is 1.31V) - it is IMO general reason for cutting that voltages in BIOS (but for 2.9V is 1.45V... I don't understand how works that Abit's bug)
(please excuse me if I write 'not exactly' english)
if its possible to change the the vdimm in bios v1.1 why should i use th old bios for oc? is it better?Quote:
Originally Posted by rapra
it will be worst - new bioses are better and have more functions. but it is possible of course
i tried it and failed. :(Quote:
am i allowed to use abits flash menu or should i do it with the floppy method?
ahh, i got it.
its not possiible with flashmenu, you have to use the floppy method.
and it works great.
A long time passed since the initial mod.
But I still get requests about final pics.
Here they are! :)
method: 10ohm fixed resistor instead of R19 and then 200ohm VR from there to ground.
ok nice work but what about r20 remove it or keep it in mobo
? and some questions i have rev 1.1 3rd eye model and mod bios from ashe
and i did rise vmem to 3.2 volts and bios is showing me that vmem is 3.3v
and the problem is that when i hit 236 fsb my screen goes black...
then when i set 240 fsb with 3.3v i get dll problems with win xp and blue screens.... so does that vtt mod help me much?
Haha legendary, bumbing up this becose trying soon dice with this oldschool mobo and cpu, modding again this mobo and trying to fit peltier block on nb etc pics tomorrow when i have had cleaned up it from dust :D
ps: sorry for bumbing this up but i dont wanna make new thread for this mobo
