Good GOD!
Good GOD!
Fugger
What kind of card clocks are you getting?
OPP
750/647
Ill incease my gpu core voltage up from 1.69v when I break down and switch mobo's
Its a flawless 750/647
Im trying to catch you with a Prescott!
Very nice clocks and scores fug, but get some insultation there!! ;)
Nice Fugger, might have to start a new thread if you drop in an EE.
damn that insane speed there.
:toast:
Very nice score with a Prescott FUGGER , any plans on dropping an EE in there when you change boards. 6 compressors LOL :)
Wonder what macci is doing this weekend ?
Is it me or has 3dmark03 started to come of age finally ? Still wish there were high and low tests though.
Good going Opp and Fugger.
Regards
Andy
fugger, thats an amazing score with a prescott!!!..considering that chip is a third of the price of an EE
The speed was 610/1340 at 3.5Ghz. Only 2 run then it died.Quote:
Originally posted by LardArse
So nice, I'll have to milk the card somemore. Thirsting for the XT meanwhile.
Tom, what speeds did your 68 do and volts before she died?
It was a spark around the heatsink in front of the 2 power slot.
I think the Gainward watercooling bios, are better to avoid trottling, or the cascade was so cold, that it was going fine.
I think it can handle 1.80volt or more, it was not the GPU that died.Quote:
Originally posted by saaya
incredible clocks!!!! -120C , respect man! :toast:
so is it possible to disable the thermal throttling of the gpu?
and how did the card die tom? too many volts?
Well Eric,Quote:
Originally posted by OPPAINTER
Tom
How about some details on that setup my friend.
What mobo, fsb, mem timings, nVidia clocks, all the specs:D.
Some good stuff to know.
Thanks,
OPP
No big secret, Asus A8v 939 Mob
Corsair dual 4400 ram (see you used OCZ for high FSB)
timings still bad cas 2.5 - etc. working at it.
and of course, still the "power" cascade you now -
:toast:
Lardarse, does thermal throttling issue on Geforce 6800 ultra hurt your attempts on re-claiming top spot?
Sick clocks, sick scores.
Fix comp today and bench w000t!
In a PM lard said he had the throttling issue "under control"
maybe Lardarse found a way to disable throttling on NV40. he' s gonna need to. but , Lardarse is the only person with the capability to match Oppainter, and Fugger with a Nvidia Geforce 6800 ultra. so, the odds of Nvidia reclaiming the crown is almost zero to nill. OC-rookie, CCW, and a few others i forgot to mention, my apologies. but Lardarse seems to be the only elite overclocker in possesion of NV40. which i find surprising. I was Hoping Hiwayman to jump into the mix as well, but he's on vacation.
I have one question, witch card do u think going too own the ORB now then the new cards have come?
The same one that already owns it until the next good card comes out. This is always the case.
Im trying to catch up ;) Give me a secondQuote:
"Is it me or has 3dmark03 started to come of age finally ? Still wish there were high and low tests though."
I still much prefer 2001 cause of that, also its much more cpu intensive. 2003 isnt and this takes the fun out of having an uber cpu when any old cpu can get within a few 100 marks away. my consoldence for any one a victim of a dead card, I thought my ti4200 had died too but it was the weak psu
3dmark03 has finally come of age me thinks. especially with SLI NV40 coming dual PCIe technology. 20k has already been broken.
I cant really understand what are the diferences of the X800XT and the X800XT PE i see many like that on ebay but dont know the diference anybody know anything? :confused:
wonder what that would score in 2001 or at least the insane nature fps :slobber:Quote:
lol, one 6800 ultra scores about 20k+ in 3dmark2001 with a P4 3.2c. i'm not quite sure how much 2 vcards will do. Good question. it's at least 77% faster.Quote:
Dual Xeon 3.40 should do the trick, it's the only one available anyways with 2 PCIe slots. maybe 40k lol:eek: :D
hmmm I think 40k would take something like a p4ee at 4.5GHz or a 2.8GHz a64 minimum even with dual 6800u's because only nature isnt cpu limited with todays high end cards. Oppainter himself only gained 1500 marks with his x800xt over Jason's x800pro and both have the same hardware. looking at the compare, only nature had any real increase. there is a much smaller but noticable increase in drag low. nothing else in any other tests. it may not be till we see 90nm a64s at over 4GHz do we begin to see the x800 and 6800u cards show increases in tests other than nature with gpu overclocks
I will break 40k next weekend!!Quote:
OPP
The difference is that the X800 XT PE actually exists and the X800 XT does not. There is no such thing as a non-PE XT.Quote:
Also, only 1% of the auctions on eBay for X800 XTs are auctions for cards in hand. The rest are criminals advertising what they supposedly have on order, and which supposedly will be shipped in two to four weeks, but THEY DON'T REALLY HAVE THEM.:mad:
