Scores as promised! The thing doesnt wanna get stable past 1.95 right now, need to do some more tweaking. Prime95 stable at 12x217
Think i got a good/bad chip?
AXMG2600FQQ4C Y911462A40329 IQYHA Q351MPMW
12x217MHz @ what Voltage prime-stable ?
1.93, but with the undervolt on my board it 1.905
oh....that's very high.....is that on air ?
if yes, then it would be just "a little" high in contrast to a "normal" XP-M2600+
i know people who are running XP-Ms with 1,750V with your clock....
Air of course :), at 2v it just gets up to 72c and shuts off
I'm right there now, just about, with 1.875vcore, air-cooled. :cool: http://service.futuremark.com/compare?2k1=7893688 EDITed in: I'm using a Panaflo 92mm fan on a Swiftech MCX462-V. I'm gonna pull it out and put the 120mm Antec on it, like I had on my old Alpha. Should be much better. Just got the Swiffy yesterday, so I'm still settling in. ;)Quote:
SUPERDUDE, you should be able to do 12x217fsb at only 1.75vcore because that is what im currently doing right now and i have the same chip as your so iam not sure why yours is crapping out like that.
I think its your PSU holding you back because at 2.6ghz and 1.75v sucks about 125w of power and i see you only got a 430w psu so im guessing the rail at which the cpu is using is not enough to support that speed. My PSU is Enermax 550w that has 40amps on every rail so i think psu playes a huge role in max overclockage.
Can you post a pic of your winbond hardware doctor to see how your rails are???
I have the new DFI installed and it's garbage!
Max OC stable is 2300 MHz for now. And all chips like MOSFETS are cooled with heatsinks so that's not the problem.
There is no difference between the Thermalright and Asetek Waterchill, infact it must be better because of the northbrige cooler and the low temps of 35 C stressed.
Help!
Is there anyone who can recommend the Abit AN7?
i cant get this thing to post on 12.5x217 :/ on any voltage from 1.7-1.95. 2 posts, but shuts down cus of heat issues
Get the thermalright slk900A with thermaltake 80mm fan with 78cfm...That should take care of the heat...Quote:
i have a slk900a with an volcano 12 EE fan :/
