Giant:)
The 2200 I have is the original core T-Bred verion..not the b version. To my knowledge there are currently no b version 2200's in the retail pipeline.:)
Randi:D
Giant:)
Randi:D
Dude....
I was thinking of ordering one of these... I saw your last post on it...
My Enermax 550w.... Has 4.8/11.8 on the 5/12 volt.... Woefully low....
How's the stablility?.... Do the Voltages remain constant, or do the move around a lot?
Any hint's if this is what I should get OPP?
Thanks, Royd
This is Amazing Icee Man!Quote:
Originally posted by MrIcee
Giant:)
These later 2200+'s(mines a week 33 AIRGA) overclock very well when excellent cooling is provided. I've been benching mine in 3Dmark at 2300Mhz for a few weeks now....and as far as top overclocks go with a 2200...hows this:D
I've Also just got my New KD-7.... Everyone put it down when I posted that I had one on order, But I guess they've quieted down now that we see what OPP has done...
I'm going to pick up another XP 2200 to play with the board.... You always get a killer deal on the current chip right right before the new one is released..... You Say AIRGA.... I'm going to another Show in Parsippany, NJ tomorrow, I'll if I can grab one..... They're going for like $150! At least on the Internet.... Maybe I should do a major overhaul and get that new PSU... From Directron like the Dude suggests... that 11.8 and 4.8 is hurting me, Ya' Think?
Royd
RoydRage,Quote:
I think OPP has 2 of those TTGI520s for review purposes...haven't heard if he is using them or what he thinks of them yet, but got a feeling he's gonna like em as much as I do.:D
Can,t beat my TTGI.:D
Yep I'm useing a TTGI 520.
The supply rocks, my 5 and 12 are perfect and don't dip.
OPP
RoydRage,
Sorry I don't know how I missed your post above. YES by all means give the TTGI520w a try.Mine is the non es model and has adjustable pot for +5 and +12. As a matter of fact, I just ordered another one a few minutes ago. It occurred to me that after OPP does his review, they might be hard to come by or more money...so I got mine now! I have noticed very slight fluctuations at high OC and a slight turn of the pot puts you right on the dime. Got both of mine at Directron.com :D
KD7 and XP2200 doing 203x11.5 2333 Mhz. Radeon at stock speed. I can tell you that this is only 1000 points away from my IT7 at stock Radeon clock when I hit 20400. If I can get my card to run the same as it did 508/360 I could get at least a 19000 score out of it.
OPP
very nice there OPP!!! Imagine if the 2400+ or higher overclock as well as the reviews with your cooling you might see 2700mhz or so assuming from what hardocp did with there's and a sk-6+ and 2400+.. what scores would come from that?? 20k+?? keep us update so we can drool :)
Wow, that's an amazing score for stock vidcard speed :eek:!
Keep it up OPP.
OPP:)
Just a couple of thoughts on the Radeon with the AMD system. I'm not sure how you're clocking is going...but the higher AGP bus speed on the KD7 vs. your Intel setup may contribute to your not clocking the card as high. I could do 484Mhz no sweat..but I had the same problem in needing to reduce the Vgpu voltage. More voltage seemed to hinder the overclock..including visual line corruption on the display. Just a thought my man...keep us abreast of your progress:)
Randi:D
Dude,Quote:
Originally posted by TheDude
RoydRage,
They have an EPS Version for more money.... Are you saying that thay one does not have the pots?
Tell me before I click ;-)
Royd
No it might..I just don't know for sure..as I got the other one.Quote:
Originally posted by RoydRage
Dude,
Royd
Opp,
With That PSU.... Is the one you're testing the EPS Version?
And If so does it have the pots for the 5v, and 12v lines?
Thanks, Royd
Thanks for the stuff MrIcee :DQuote:
OPP:)
Randi:D
I was stuck on stupid for a while. I was testing 3D at 200 plus fsb and could not plug my GPU v-mod in at all, it just would not run with the higher voltage. I changed the pelt put in a 220, but no help, I was thinking that the AGP voltage from the KD7 was to high at 1.54, I just couldn't figuer it out.
Well I'm back to 500mhz on the card thanks to you My friend testing it at 150 FSB using 1.78 volts on the card again.:)
Now I have to see how High I can go with my FSB before it starts to screw with the Radeon Clock:D
Royd,
I'm sure it has the pot in it, it is the same supply but the only difference is it has a 24 pin plug instead of the 20.
OPP
Thanks Good Sir....
Royd
Good lord. These 9700's sure are finicky aren't they?dQuote:
Royd,
OPP
OPP and sys:)
Do you guys see why we needed the 1/6th divider now?? Especially with the 9700. Top AMD scores = 200Mhz= FSB plus OPPs 500Mhz GPU clock. Without the 1/6th its going to be difficult...best scores are done at highest bandwidth via the motherboard.....so there will be a fine line of finding a decent FSB and being able to clock the card. Good luck my friend...I know you can pull it off:)
Randi:D
MrIcee,
I'm getting no where with 3D mark, I can't even hit the front page. 18300 I think, and it was done at 203 fsb without v-mod hooked to the card. Card was doing about 450:rolleyes:
Yeap other then that I can do about 500 when useing 194 FSB but I'm getting worse scores:D AMD has a way to go to beat these Intels doing 3600Mhz :D
On the other hand, the board is good, I like it. A couple of big problems though. I run this chip at 1.98 volts at 2320 stable with 202 FSB, the problem is the heat of the Caps on this mobo. Now I know were the temp readings must be coming from, and they are an under statment:D There is an area above the AGP slot that has about 4 mosfets 4 Caps and some of those donut coil thingys, this area could cook your eggs for you at breakfast, you could burn your finger on it. I would think that after a while somthing while fry.
Great Overclocker but bad for 3DMark if you run a v-mod on the card. I swear I can smell this sucker burning:D I ran it all night Folding and it didn't catch on fire so I gues the sucker will survive another day.
OPP
If the Radeon 9700 card won't overclock, why not go back to the GF4 Ti4600 card you use to do 3d mark scores with ? It was a good card and with the det. 40.41 and a good overclock maybe you could get a better 3d mark score then the one you got with the Radeon 9700 OPP ! What do you think ? :)
Tecnoboy,
Welcome to Xtreme :)
Welcome to Xtreme:toast:Quote:
Yea the card will overclock and even run at high FSB the problem is that you can not go with higher GPU voltage at these high FSBs.
The GeForce would be fun to try though.
OPP
Thanks for the beers boy's ! :D It's good to be here, Im all arround the forums, since Portugal to Australia, this was one of the last I wasn't participating, only whatching ! ;)
"The GeForce would be fun to try though."
OPP: Then try it already !!! :D What are you waiting for ?
I think he wating for the radeon to catch of fire :D
Anyway, great work OPP, as usual :D
One problem, I don't have a G4 any more:(Quote:
OPP
