ABIT NF7-S Rev 2.0 EB RAM test results
I just finished some extensive ABIT NF7-S 2.0 testing. The brand new board I have will not run 2 x 512mb BH5 RAM any faster than it will run the PC3200 EB. I feel that the chipset and/or bios on these boards is holding back the overclocking with the 1gb (2 x 512mb) kits, no matter what RAM type they are. I was able to hit 217fsb in dual channel mode with ZERO errors. This was using the Tic Tac D22 and Official D23 bios.
The ABIT board is being held back by the 2.9v DDR and 1.7v Chipset maximum settings. The Nforce 2 chipset is very agressive and needs the voltages and a bios that will allow the higher FSB settings.
The same RAM in a DFI Ultra Infinity NF2 board with the latest official bios will run 237fsb stable with ZERO errors in memtest using the advanced voltage settings.
Each board will be different as the NF7's seem to vary quite a bit. The good news is that the 1gb kit will work and overclock better on some boards than others.
With a Barton Mobile CPU the 166fsb "wire mod" IS required to be stable at 200fsb or over.
I hope this info helps.
Andy: what about DFI, mobile and wire mod???
Did you try it to see if it made any improvement at all (maybe move the highs higher?):D
Thanks MikeE
