Originally Posted by
StyM
:welcome:
i'm not using that file, i believe that file is for single CPU only.
there are two files for use on 2P system, you may look for v3x2.efi (3.0ghz) or v3x2_mc39.efi (2.7ghz) , i'm currently using v3x2.efi for full turbo.
went into the efi shell and loaded the v3x2.efi file, copied it to the efi\boot folder.
unfortunately supermicro efi shell doesn't have bcfg, so not sure how to make the efi driver stick permanently.
so for now, everytime i reboot i have to load manually the driver... :(
