If i'm not wrong, before when i used to have it at 3780 on windows sandra told me 106w... if my memory isn't cheating me...i didn´t see yet at 3855...got to install sandra to check later...
Regards
Vortan
Regards
Vortan
To keep on this subject...
I ordered a P4 2.8C w/ the following the code:
SL6Z5 COSTA RICA
3349A591
4349B263
0814
Now, I don't have a motherboard for this yet, it'll be in a P4P800, anyone have experience with this chip? Btw it has the "new" bottom look, like the one that was pictured in this thread.
hi sys,
long time, no see. :)
I have 2 of those SL6Z5.
One does 3650Mhz, 1.675V, air cooled on my IC7-G.
The other does 3.7Ghz, 1.60V, WC on my P4C800-E.
Think that you should be able to reach those speeds, maybe even higher.
Good luck with te chip.
Cool thanks for the info--btw it says pack date 1/15, just looked--so it's not the newest but it'll do :P
If it doesn't turn out good I will probably sell it and get one of those new 3.0Cs :)
EDIT: And I forgot to mention, I'm getting a Mach1 for my b-day in April, so... :) That'll help heh
Has anybody in the US purchased one of these new 3.0s, or bought one from an online store like newegg?
Just got meself one of those SL6WU 3.0G NW yesterday as well.
Had the chance to test it in my Max3 today with the boxed cooler, I too got 15x250fsb 5/4 @ 1.575v.
Seems to be okay this CPU. Haven't tested it in my Vapo yet as I killed my IC7-G (mobo in Vapo) while trying to set this CPU in it.
So bloody hard to change a CPU with this Vapo, after 4 hours of trying to boot up the Vapo, afetr resating the CPU & Vapo so many times I ended up killing my poor mobo (best mobo I have as well).
Oh well, gonna be spending the next couple of days getting this p.o.s Max3 up to spec (vmods) & the I'll have a crack at seeing how high this 3.0Ghz baby can go...
Not too bad result with this 3.0 CPU with just the stock cooler, already higher than my best with my trusty ol' 2.6....
Dude thats a killer chip.
Im gonna put away this amd setup and buy one :):)
*20 minutes later*
Ummmm maybe not bit too pricey here in aus.
Their good indeed. Running at 248 FSB at 1.525. Watercooled.
Funny thing is that I can't get it over 250 even with 1.7 Vcore (lol)
Gonna test it on a MAX3 card some day in the future.
Wow, seem like lately these 3.0C sl6wu is doing pretty good. I might go grab me one to play with on my air system as well.
lookin great guy's.
I had picked up a 3.2C from GoogleGear 2-3 weeks ago with a stepping of SL792, and it has the same cap pattern as my M0 stepping 2.4C CPU-Z shows it as a D1 though just as your SL6WU's do.
Unfortunately I haven't seen as good results as these chaps, but I still have some things I need to sit down and fiddle with. 3840 has been my highest stable boot speed at 1.625v with plain water and 25°c ambient. Last night I tried up to 1.7v and it would boot into windows at 4ghz but would error as soon as I went to load on a bench. I really feel I need to do this droop mod and quick.
ok, have done some testing with my 3.0C SL6WU, L350A776.
Zalman 7000cu: 3600MHz, 1.55vcore, dual Prime stable, after that serious heat issues.
Watercooling (WW, 3x120mm, Eheim 1250): 3950MHz, 1.7vcore, dual Prime stable.
Prommy Mach1: 4100MHz, 1.675vcore, dual Prime stable.
SuperPI:
http://www.nordiccrew.com/crotale/superpi32s.gif
PCMark:
http://www.nordiccrew.com/crotale/pcmark10611.gif
All tests done with Mushkin PC3500 Level2 @ 5:4 2-5-2-2
Didn't try it yet in 3d applications...i will put conclusions later...
http://www.pcdiga.com/Imagens/VoRtAnMaDgEOUCH.JPG
Cumps
Vortan
OMG!!!!!!!!!!!!!!! stock volts!!!!!!
give it 1.75V!!!!!!!!!!!!!!!
It's the same...no matter how much volts i gave it it's the same oc...
I know what he needs...Cold, lot's of cold :D ...
In bios i can't boot more then 257mhz but in clockgen i'm going up...
Let me see te limit of it:) ...
CUmps
Vortan
<brain fart deleted> :stick:
What MB do you use?
These are not Prescotts...Quote:
Originally posted by Kosmic
1.75 might be a bit much since these prescotts are already running incredibly hot. It'll be interesting to see if the new stepping that's coming out soon will help the heat situation. In any event, it's nice to see these Prescotts getting some very nice overclocks.
This is not Prescotts, it`s Northwoods :D
Sorry, thought I was in a different thread. My bad.
very nice chip. would like to get my hands on one.:)
got me a new toy today :D
3.0C SL6WU L350A642
i love it lol
first quick test
water 15°c 1.525v bios
http://learn.chez.tiscali.fr/3.0C/firsttest-1525.png
1.575v bios
http://learn.chez.tiscali.fr/3.0C/firsttest-1575.png
Where is everybody getting these SL6WU CPUs from? I will buy one today if I can be sure that's what I'm going to get...
Ya do u guys know a place that have these 3.0 and that can ship in Canada???? i hope u guys have a anwser.
My 3.2C (SL792) does 3.7Ghz stable on stock volts
@ 1.8v I can get into windows at 4Ghz but not stable I think its a power issue because games run for awhile then it freezes...
I guess all the stores has the new SL6WU, its the only one Intel produce's of the 3.0C. Try contacting the webshop's and ask them. If they dont, the next shipment will be with them ;)
