Does any one know how this compare to a Q9450 (775 socket), on 3D Revit?
Hey FNG, I was wondering if you are using the drives in the photo for those overclocks? (The WD Green and Corsair SSD). I can't get much passed 105 Bclk without Windows7 rebooting during start up which makes me suspect the old crappy drive I'm using (Seagate ST316012AS) may not be tolerating the increased clock.
Anyway, any insights appreciated.
Anybody delide one yet?
Yeah I was interested in knowing whether indeed this latest AMD chip is any stronger than a 775 socket cpu. I know AMD lapses in performance compared to any current Intel hardware just little confirmation relating to performance with older Intel cpu's is released, is there something suspicious going on here?
I got it sorted, disabled AHCI which was enabled by default, re-installed Win7 on a new hard disk and is working better now. I've only taken it up to 125 BCLK so far and it's running pretty good. I'm guessing it simply had to do with not running in IDE mode.
Seems like the PCI-E slot doesn't have a locked clock.
More OC results!!
I wasn't going to overclock as I had previously heard only 100mhz or so was possible. 2.5ish would definitely make it worth it. What tweaks or settings are you guys using to overclock? Is everyone enabling IDE mode? What kind of clocks can be expected in AHCI mode?
Asus am1l-a
5350, stock cooler
kingston ssd
400w ps
r7 260
bumpz
get a good air cooler and just start messing with the bios. add some volts. and lower memory timings
disable achi mode i think...correct guys?
check asus bios setting earlier in thread
Never deny a kid of an xtremesystem ;)
Just noticed Asrock added some overclocking functions in a BIOS update to one of their ITX boards:
http://www.asrock.com/mb/AMD/AM1B-IT...wnload&os=BIOS
