Originally posted by ricjax99
W00t :toast:
I mentioned the 2400+ mobile as i reckon they are designed to run at low voltage and decent clocks, usually if a chip does well at low volts it opens some serious wupass with more :D
The Rev B is shown at the store i buy stuff from in the UK so i think its normal. I think the first infinity was a KT400 lol so mebbe its so no-one mistakes it for that heheh.
The 2800+ i have is an AQUCA chip, the same stepping as the 3000+ and probably a 3200+.
It prime stable at:
2.43 GHz @1.75v
2.53 GHz @1.93v
3D Mark stable at:
2.55 GHz @1.95v
PiFast sable at:
2.57 GHz with 2.06v.
The max i have got into windows at is 2.67 GHz and the max i have posted is 2.7 GHz.
This is using an SLK900U and vantec 92mm tornado, thel prime 3d mark and PI Fast testing was done with the case sides on too ;) So at -120 i think you'd manage at least 3.0GHz :D
I imagine you'll get something similar from a 3200+, mines a week 28 btw :)
That is a week 28... it is half a year old! The new ones will go better ;)
