Hey C-N it is simply the uncore + secondary and tertiaries. 4800 uncore a.k.a. cache should yield better results, but having core at 1:1 with uncore is going to be the fastest if you can get it to run, but I find it harder with all the retail cpu's I have tested so far, some needed as little as 1.5v others 1.65v all under cold to get 5Ghz uncore.
Also remember no need to run uncore higher than core, this is different in regards to X58 as this will yield a negative impact on your 32m time.
