OK then folks ..... As of 2300 BST today I have switched my rig "Arachnid" over to 1.S. (using the command line in linux and the:
from Bluestang's post above)Quote:
boinccmd --project http://www.worldcommunitygrid.org detach
boinccmd --project_attach http://www.worldcommunitygrid.org 681782_2df3fe53ee2df6da1a8c26b35b2a859a
The rig is not overclocked and has only had a day running to test but should be good for 32 days per day (less any overhead) it has been running a big variation in times per wu at between 3.07 and 4.89hrs making it difficult to estimate how much work is in cache in days
I have a gut feeling that the 1 + 8 is wrong and that it should be 8 +1 but not sure why. Comments?
Thoughts:
This may be more than is needed so folks might consider jumping to mumak on gfam if needed
A fast completion might allow for ability to jump before hpf2 ends so we might still get wu's for that if people need them
(I am still not really clear on who needs what just now)
Local cache here is set for 1 + 8 and I will watch that to get a feel for what is needed and if the change mentioned above is required
