I don't think you have to use that fitting if you don't want. I'm sure you can use the one on the bottom right and get the same effect.
just want to clear up,
so if i already have the old vga supreme hf, i just need to buy the top and the parallel bridge?
hillywav: True.
The Bridge Edition waterblocks will be available for purchase next week!
Just something I'm curious about: say you have 2 GTX 590 (I know, crazy :eek:!), would it be possible to use two of those sets to cool those 4 GPU's?
Also, I assume this product scales along nicely with 3-way and 4-way SLI/Crossfire?
I see no reasons why it shouldn't be possible. You use 4 block and two bridges - bridges have outlets/inlets on sides so connection should be easy.
If I knew about bridge edition earlier I would wait and get one. Instead I got normal HF block only 3 weeks ago and will have to get ~€15 top...
tiborrr: you can post some renders with 590/6990 dual gpu cards && these, it might look interesting indeed. :)
I'm thinking though that such higher end cards definitely need some extra cooling on mosfets, so maybe not best candidates for universal blocks, unless it gets taken care of.
5 more days! Are these only going to be available on Ek's website on Nov 1st or other water cooling shops? If other shops any idea which ones? Waiting to add to my cart :)
hi tiborrr:
i have 2 pieces of sapphire 5830 extreme, wonder can these bridge edition blocks can fit on 'em? pls advice, thanks in advance. :)
in stock!! :)
http://www.ekwaterblocks.com/shop/me.../file_36_6.jpg
2 LED slots would have been better, not sure if this is the best place for a nice effect with LED :(
Anyway, are you planning on releasing EK-FC Bridge in plexi too? :)
I wonder if there was need to make transparent tops. Imho just one, black, was sufficient, as it goes so well together with looks of SLI/CF bridge itself.
Yes, HD5830 Extreme fits this waterblock :)
We're working on a plexi FC Bridge, but at this time we're optimizing the production to achieve best finish quality and to make it economically viable.
I see Performance PC's has replacement tops available now. But not entire blocks. Hopefully we'll see the entire complete block available in North America soon.
They should be available next week in North Americas IIRC.
Here are the prototype plexi bridge's I have promised earlier. Right one is a bit scratched though but the boring of the holes is perfect :)
(serial sample though as the machine was programmed for serials when this prototype was made)
http://file.si/pfiles/212156/DSC_0234%20%282%29.JPG
hi tiborrr, do i get a O ring when i buy a new top for my current vga-supreme hf?
Hi,
yes, an o-ring set is included with the EK-TOP kits.
why dont you guys offer a full cover heatsinks?
does this block fit with swiftech full cover airsinks?
the only way that I would buy this block is if I could get a full cover heatsink for it. :up:
NKRader: Perhaps with upcoming generation of graphics cards? :)
Hi Tiborr
Do you know where we can get only the replacement top? In US\Canada...
Do you have an estimated availability for the plexi bridge?
Thanks!
Hi, will you be producing a plexi version of EK-FC Bridge DUAL Serial 3-Slot?
also release date? as i want these so bad :D
nice work as ever guys, i have one of the new VGA tops allready, they look awesome and work perfectly.
can't wait to get another card and another block to Xfire them using the Bridge.
Looks very good this Bridge :up:
