Originally Posted by
Utnorris
The problem with most cases that claim to be water cooling cases such as Corsair, Lian Li and even Silverstone is you are limited to the amount of rads you can put in it. For most this is not an issue as a single triple rad and dual rad will cool the average computer better than air coolers. The problem is if you want to do a build with large rads, multiple loops or multiple pumps you are very limited with the standard tower type case. Granted, from a "Cool looking" perspective a cube is not great, but you do not have to worry about modding it to fit various rads, multiple pumps or several hard drives. With a tower you have to sacrifice something in order to gain water cooling room, just that simple. Look at the 800d, you have to remove the lower cage and cut the bottom in order to fit a second rad. The TJ07 has to be modded, hence is why there is Murdermod, in order to get several rads in there and you lose HD spots. With Case Labs, MM or even the XSPC case you can fit three triple rads without modding, a couple pumps and various other gear. They are not perfect, but Case Labs has definitely improved upon the "Cube" idea. Even though the XSPC case is pretty much a MM UF2O knock off, they made some interesting refinements to their case. As much as I hate wire management in my MM cases, I love the fact it has a horizontal MB tray and has plenty of room and it's modular. I like the Case Labs better, but I already have the MM case, so switching to them would be a tough choice for me. It really comes down to what is important to you, if you want to make a fashion statement then the "Cube" is not for you, get a Lian Li case or Betfinix case and have fun, but if you want room to do stuff, then the "Cube is the way to go.
