Originally Posted by
NaeKuh
no no no your looking at the system as 1 big system.
When instead its 2 active systems fighting for equalibirum.
The system which is tank -> rad -> tank... can be kept small, and on bigger diameter tubing.
since flow controls how much heat is carried and dump'd, obviously bigger tubing, using a fish pump to a car rad, or some type of rad of that size is going to have a tiny flow drop.
This is system 1.
System 2, is from the tank to your computers.
Now assume... each of your system is taking 1gpm of flow..
That means 2 systems u got 2 gpm of flow going back into the tank.
Your tank will have way more X gpm of flow to the rad and back, if u designed it right.
As you can see your tank will be kept at close to ambient at all times unless u have an insane massive heat dump going on.
