I was wondering why you don't put copper pipes for sli connections and for connections in the bottom of your case?
Update 13
After long days of filling and sanding the body is ready for paint. I only have to do the sidepanels now and then it can go to the painter.
Last week i also received my new Motherboard Gigabyte P67-A UD5 B3 version
So i installed it with he 2 HD 6970 so i can finish my loop.
And i finished my pump also with the stand and the flow meter.
But first the Case
With my previous Project Umbrella i had to make some holes in the bottom of the case for the drain and some mounting holes.
http://i1187.photobucket.com/albums/.../SDC101432.jpg
These are all gone now
http://i1187.photobucket.com/albums/...e/SDC10134.jpg
http://i1187.photobucket.com/albums/...e/SDC10143.jpg
Removed all the scratches that i made on the top case
http://i1187.photobucket.com/albums/...e/SDC10132.jpg
http://i1187.photobucket.com/albums/...e/SDC10133.jpg
http://i1187.photobucket.com/albums/...e/SDC10159.jpg
http://i1187.photobucket.com/albums/...e/SDC10160.jpg
After all the sanding it was time to put the case in to the shower to wash all the dirt off
http://i1187.photobucket.com/albums/...e/SDC10168.jpg
The pump
Because the i had to turn the pump to put it on th stand i couldnt reach the the bottom to adjust the speed of the pump.
I had to make something so i could still do it. without moving the pump
Drill a hole
http://i1187.photobucket.com/albums/...e/SDC10144.jpg
http://i1187.photobucket.com/albums/...e/SDC10145.jpg
http://i1187.photobucket.com/albums/...e/SDC10146.jpg
Locktide on the screw so it wont move around
http://i1187.photobucket.com/albums/...e/SDC10148.jpg
Also finished up the stand of the pump.
http://i1187.photobucket.com/albums/...e/SDC10150.jpg
http://i1187.photobucket.com/albums/...e/SDC10149.jpg
http://i1187.photobucket.com/albums/...e/SDC10151.jpg
Like this i can still reach it without moving the pump around
http://i1187.photobucket.com/albums/...e/SDC10152.jpg
Replaced the power connector so i can plug it directly in to the PSU
http://i1187.photobucket.com/albums/...e/SDC10154.jpg
http://i1187.photobucket.com/albums/...e/SDC10165.jpg
Because i couldn't find any white housing for the flow meter i decided to make it white my self
http://i1187.photobucket.com/albums/...e/SDC10267.jpg
http://i1187.photobucket.com/albums/...e/SDC10268.jpg
http://i1187.photobucket.com/albums/...e/SDC10269.jpg
http://i1187.photobucket.com/albums/...e/SDC10271.jpg
The Motherboard
Installed it on the tray with the HD 6970
http://i1187.photobucket.com/albums/...e/SDC10169.jpg
http://i1187.photobucket.com/albums/...e/SDC10170.jpg
http://i1187.photobucket.com/albums/...e/SDC10173.jpg
Completed a other piece of the loop from CPU to GPU
http://i1187.photobucket.com/albums/...e/SDC10186.jpg
http://i1187.photobucket.com/albums/...e/SDC10187.jpg
http://i1187.photobucket.com/albums/...e/SDC10180.jpg
http://i1187.photobucket.com/albums/...e/SDC10182.jpg
Tray in the case
http://i1187.photobucket.com/albums/...e/SDC10276.jpg
http://i1187.photobucket.com/albums/...e/SDC10281.jpg
http://i1187.photobucket.com/albums/...e/SDC10273.jpg
http://i1187.photobucket.com/albums/...e/SDC10278.jpg
http://i1187.photobucket.com/albums/...e/SDC10277.jpg
I only have to make the connection between the midplate and CPU and then is the loop completed then i can start the sanding and polishing of the pipes
Sponsored by Highflow
http://i1187.photobucket.com/albums/...n-s/header.png
Completed Builds
Project Umbrella
Black Obsession
great job :shocked:
Eager to see more :slobber:
epic build sir. those copper pipes are gonna look awesome in white.
Today irecieved a package from Marnix AKA UgotHeinzzd
With Commandant nr4 and some extra O-rings for the fittings.
Thanks for the tip and the stuff man ^^
http://i1187.photobucket.com/albums/...e/SDC10329.jpg
http://i1187.photobucket.com/albums/...e/SDC10330.jpg
When i came home i immediately started with polishing the pipes
Copper pipes naturel
http://i1187.photobucket.com/albums/...e/SDC10320.jpg
Copper pipes sanded to 1000 grid.
http://i1187.photobucket.com/albums/...e/SDC10321.jpg
Copper pipes polished with Commandant nr4.
http://i1187.photobucket.com/albums/...e/SDC10322.jpg
and the result it is just WAUW ^^
http://i1187.photobucket.com/albums/...e/SDC10323.jpg
Started with the pipes in the case that where sanded already.
http://i1187.photobucket.com/albums/...e/SDC10326.jpg
http://i1187.photobucket.com/albums/...e/SDC10327.jpg
http://i1187.photobucket.com/albums/...e/SDC10328.jpg
I really love the result of it i am falling in love with it :p
Completed Builds
Project Umbrella
Black Obsession
WooW god of Case modding !!!
use of Micro LED white & blue in chassis Body.
Thanks and thanks for the tip but i probably use 2 leds only and they will come in both reservoirs. And maybe some SMD leds on the plexi of the GPU's but that is not sure yet ^^
Looks great!
What fittings are you using to attach the pipes? I've only seen pipe compression fittings from koolance, but yours look like bitspower.
Please please please don't do anything more to those copper pipes, it looks INCREDIBLE!
Thanks Whiteroom
your right Guilleguillaume
Sorry XC but the pipes will get a coat of nickel. I know they look great like this but they will look even better with nickel around them ^^
^While i am at it i will show u the final pictures of the loop.
I finished the copper pipe loop + all the pipes are prepared to get a nice shiny coat of nickel around them :p
http://i1187.photobucket.com/albums/...e/SDC10333.jpg
http://i1187.photobucket.com/albums/...e/SDC10341.jpg
http://i1187.photobucket.com/albums/...e/SDC10343.jpg
http://i1187.photobucket.com/albums/...e/SDC10336.jpg
http://i1187.photobucket.com/albums/...e/SDC10335.jpg
And a picture for the Highflow case badge contest ^^
http://i1187.photobucket.com/albums/...e/SDC10338.jpg
Completed Builds
Project Umbrella
Black Obsession
The copper is outstanding! Great job all around.
Those pipes do look great...I guess the nickel coating will look great too.
:yepp:
I'm ready to die now.....
I just needed to see this first.....
very beautiful work
I got an idea with the copper pipes ..... acid etching .... it'll be gorgeous with some marking ... preferably tribal?
Thanks man
It has to ^^
Lol don't die before u see the end of the build :p
thanks ^^
Looks like a nice idea but don't think it will fit with the rest maybe in a other build ^^
What holds the tube in the fitting? The weight of the tubing + water wont affect how well the fitting "holds" the tube?
Top notch cousin from Belgium
C'est écœurent comme on dits en bon français du Québec
While pipe from gpu blocks till cpu WB looks nice .. why not change it to shorter one that comes from below of gpu waterblocks? This way you'll eliminate top 180degree fitting combo, by what flow restriction should drop.
I thought the copper looked stupid, and then you polished it. Now i want to get some good pipe benders :D
2rubber sealing that are in the fittings hold the pipes
Atm there are no problems with it but i will keep u guys up to date when i start to fill up the loop :p
Thanks mate
Have bin thinking about it but for that i need to use allot more fittings to get the pipe at a good position. Plus i kinda like how it is now ^^
lol :p
Completed Builds
Project Umbrella
Black Obsession
