Originally Posted by
Vapor
PK-1 and MX-4 are already done, PK-1 was a knockout winner. :p:
Shin-Etsus are months away, I'm trying to alternate batch sizes of 2 and 3...Shin-Etsu will be a 3-TIM batch. If I'm on batch 0 right now, Shins are going to be batch 6, roughly 3ish months away. I'm curious to see if X23-7783D can keep up with PK-1 at moderate contact, my hunch is "no" based on how well PK-1 thinned out. I have no idea what to expect from X23-7762 and G751, but based on Shin-Etsu's own data, I'm not expecting much.
And thanks guys, each TIM takes 150 hours of CPU loading, so it's good to hear people are appreciating it :)
As for the IX issues, make sure the board is level, make sure your block isn't on too tightly (about the same pressure you'd get from a stock Intel heatsink or an Apogee XT or an EK Supreme HF Easy Mount, I suppose), and make sure your heatsink/block has a smooth base (no steps, no HDT, avoid superbows). I do two reflows every 7-10 days for my CPU block tests, and I don't do any tricks to get it to work. I'd say 5 out of 6 reflows are completely successful on blocks I've never done before....and basically a 100% success rate with ones I have done prior.
Miah, the one in your pictures is almost certainly from not being level. :(
Utnorris, yours does sound like too much mounting pressure. I make sure I tighten down the same amount on all four corners, then the non-bulge side I'll loosen slightly if there's a bow and tighten it when the PCMA (solder) is liquid. Considering the mounting pressure and bow I used for Great Contact setting, I wasn't expecting it to work, but it did (a look at the used ETIs looks bad, but temps were right on).
Yeah, thinking too much pressure.
I don't really think there's any trick to it....but I got it right the first time and since then I've just tried to stay the course. Occasionally I'll try to do something a little differently, but I never find any benefit when I do. I can imagine if I didn't do it right the first time I'd be trying to overcorrect and be generally uncomfortable with it. Fortunately the Apogee GTZ I did it with first was very amenable to the process (right amount of pressure, copper base is a little more reflow friendly, bow wasn't too extreme). It's definitely the hardest TIM application out there and if you know you have really good contact, I don't know if I would say it's worth it over a PK-1 (or X23-7783D from my other tests).
I'm surprised no one else is very alarmed by the MX-3 batch differences. Assuming IX is .5c away from 'perfect,' new batch MX-3 (both tubes purchased when MX-4 released) is 125% worse than original batch MX-3 (purchased at MX-3 launch) with Poor Contact. I've used (with full-on monitoring) multiple batches of Shin-Etsus, MX-2, Ceramique, PK-1, IX, and AS Matrix and there hasn't even been a hint of a difference. Original batch MX-3 was the best of any paste with Poor Contact, new batch MX-3 was one of the worst. Even more alarmingly, the TIM prints made me think pump out was only a few thermal cycles away from happening.
