:shrug:
Edit:
1. Fill device SSID.
2. Update LAN PXE ROM.
@Stasio
Is it bios v1.8b7? Cause I flash it and it says bios v1.4:shrug:
downloaded from hwbot and that's fine
http://hwbot.org/forum/showpost.php?...&postcount=177
Puzzles me then knocks 2seconds off superpi 32 time compared to old bios! That i posted at the begining of thread!
http://img651.imageshack.us/img651/4615/93964939.png
then meaby they changed something more:)
1.8b7 bios vdroop is still, in terms of overclocking, nothing has changed
what settings should be included in the "CPU Feature"
please help
the new bios 1.8b7 is more difficult to stabilize the 5GHz on my 2500K Voltage 1.485V set in BIOS, provided a lift of 100% is charged 1.51V, vdroop control does not work
over 25 minutes Prime95 x64 stable for now
http://img200.imageshack.us/img200/5...z2471485vb.jpg
My New 4GB G.Skill DDR3 PC3-17600 CAS7 2200MHz RipjawsX on P67A-GD65 using new bios 1.8B7!
5Ghz 1.36v Cas6 Timing unreal! I think i can get them tighter to and i abit faster freq left in them!
http://img717.imageshack.us/img717/8...hz2100cas6.png
1.64 i left it on auto in bios on control center it show 1.6467v!
Tighter timing 6-10-8-24 1T
Does anyone know what chip these use have never had memory like it!
http://img684.imageshack.us/img684/6...as6108241t.png
IO voltage also auto?
U can disable SPREAD SPECTRUM, so cpu-z show 100Mhz x51 instead of 98.8Mhz.
Have set it to 98 bus speed 100 wouldnt get to windows boot screen needs tweaking at 99 at minute! Am running IO Voltage on auto shows 1.3v!
Interesting info!
i found it on MSI forum
"E7681IMS.170 [Final] ---> E7681IMS.187:
- Fix Memory issue(G.Skill F3-16000CL9D-4GBTD/G.Skill F3-12800CL80D-8GBEC0) when Adjust timing to 7-7-7-21.
- Fixed "Windows Boot Manager" will lost when after flash bios from Boot Order.
- Update ChangeLogo.efi and modify string by FAE request.
- Modify some string and CPU Specifications for setup spec v0.17
- Update Utility:ChangeLogo.
- Update BIOS setup string(Memory Test page/MFLASH/oc profile).
- Update GPower module to follow H/W recommend.
- Fill asm108x device SSID.
- Update LAN PXE rom2.38."
bro2000 can you post a bios template of your settings please?
hmm got a problem, can't save the bios settings. If I save and reset(F10) it just freeze. using the last bios 1.8b7.
Already flash it with another bios but same problem exist :(
Also it shows a cpu speed of 20.87GHz in the right corner.
http://i82.photobucket.com/albums/j2...K/Foto0602.jpg
Turn psu off
Switch Clear Cmos jumper 2-3 and then bk to 1-2
Turn psu bk on should solve your problem!
Back to old bios prefer it with this memory!
1047Mhz 6-9-6-27 1T 1.68vDimm 32m Stable
http://img511.imageshack.us/img511/6...cas696271t.png
Mobo setup. But I can not get it to go into bios setup. Have cleared cmos, keep hitting DEL but it just goes to bootup screen.
Its happened to me before MB disable keyboard if bad oc!
Try doing following steps
Turn psu off
I did several clear cmos and use different biosses, only bios v1.4 I can save again.
A lot have troubles same as me
http://forum-en.msi.com/index.php?to...0223;topicseen
Did support a ticket with MSI.:(
Running 1.8b6 any change in overclocking settings in bios as soon as I hit F10 bios locks up. Thats any change like increase multi by 1.:mad:
Max out 2200Mhz 6-10-10-27 1T Running with 3.4Ghz stock clock! Msi board doesnt like running 2133Mhz ratio at 100+ Bclock at 5Ghz very weird hope there a bios fix soon!
http://img24.imageshack.us/img24/323...z61010271t.png
Trimming it down! Ashame am having issue with msi board i do think these will do 2133Mhz 6-10-6-24 1T 5Ghz
New test 6-9-6-26 1T 1.66VDimm
http://img511.imageshack.us/img511/6...96261tbest.png
