no problems in bc2 for me (except for from flickering textures on some maps)
i used to have sound issues with my 5850 tho
this thread make me want to swap my 6970 to 570 Haha
my lil devil
my GTX570 arrived today - will post clocks tomorrow :)
its a MSI one - was cheapest one I could find (reference cooler) - but out of box is fairly overclocked, 786mhz on core and 4200 on the RAM
core is nothing special but the RAM surprised me as an out of the box clock
just short of 6k >_<!
.963 stock vid, max load temps 68 degrees under unigine's heaven benchmark. should be able to break 6k if I switch pcie slots, but this config is further away from my cpu and done to reduce heat.
http://img341.imageshack.us/img341/4224/3dmk11.jpg
-EVGA Reference 570
-266.77 Drivers
-stock vid 1.025v
-21.1c ambient air, 68c peak card temp @ max fan :cool:
-1.1v :confused:
-900/2200 clocks
-no visible artifacts at any tests during three runs :D
3DMark11 Result: P6336
Hello, does anyone have the bios of the ZOTAC GTX 570 AMP! ?
I do not find it anywhere.
thanks :D
Happy me and my 570 :)
http://www.abload.de/thumb/rekord3d11_570g7df.jpg
I haven't tried more yet...i was hunting the "milestone" :D
Gigabyte GTX570 OC Windforce 3x
cpu and mem's relaxed...concerning stability in the rest and stressing vga
100% fan
Stock cooler
1.2v (didn't try less)
http://img189.imageshack.us/img189/7285/gtx5701ghz.png
I just ordered a pair of those MSI GTX 570's to replace my GTX 580, I need more speed! The out of the box memory clock is pretty nice-looking... they're due in Wednesday :D .
Got it off newegg for $350/ea but it has a 30 rebate, a free 4gb ddr3 sodimm, and just cause + mafia 2 coupons for each one (rebate's only valid on one card though). I figure I can sell the RAM and 4 game coupons to get a good chunk off the total, as well as my 580. Hoping I end up at around $100-130 for the upgrade, and if the rebate comes subtract 30 from that :up: .
I'll post my OC results in SLI soon!
EDIT: 9% off coupon now too, should save me $31.50 each if they apply it, they usually will while it's in transit :D .
Yes very nice...another 570 going 1g .
guys what are the best drivers for GTX570 SLI i just jumped to them from 460 SLI
thanks in advance !
Sergio
I have a GTX 570 SC and MSI afterburner does not allow me to change voltage 0_o .. what to do?!
do you have MSI Afterburner 2.1.0 beta7 or 2.1.0 final?http://forums.guru3d.com/showthread.php?t=339433
Never, not NEVER!!! run new FurMark ver. 1.9.0 on GTX 570/580, it smels cards very fast, one can't boot now, and in system started from second card in other PCI-E slot, first even can't be seen in system, as there is no any other nVidia PCI device.
here my score
http://hwbot.org/signature.img?iid=5...se&iehack=.jpg
Does some1 can help me to make a mod 260.99 win7 X64 inf for my GTX570?
