If they start making noise, then its a six month wait after they start shouting, if they stay silent then Q1 2011.
22.10.10 and no leaked benches ?
madness !
Sexy looking. :D Can't believe how secretly it's been kept with this close to launch. It only seems to get worse and worse.
Another angle
http://www.techpowerup.com/img/10-10-14/75b.jpg
can anyone give us its length from that image?
I hope AMD positions 6850 against GTX 460 768MB and 6870 against the 1GB version. If they put 6850 against GTX 1GB if they perform similarly, then there's nothing to go against 768MB version.
the length of the Xfire bridge, and the 6pin connectors should be able to tell you enough
ill give it a try and see what i come up with
Just measure the crossfire bridge on a real card, see how many times it fits the side on the pic and voila there u should have a quite accurate figure.
Nope
Same photo just flipped by 180 degrees :rolleyes:
Imho it is more reliable to do it with PCI-E power connectors.:)
this is a comparison to a newegg image of a very similar angle 5870.
sorry i cant really give any numbers, but someone else can probably count the pixels to know what its around.
the vertical green lines are for lining up the top edge of both cards, cause they are both skewed a little
http://img89.imageshack.us/img89/9099/x870compare.png
Nono, just do it like this:
http://i55.tinypic.com/2edti53.jpg
Quite exact 16½ PCI-E connectors for the PCB itself... too lazy to measure the exact size of a PCI-E connector atm.
EDIT: OK I measured the pci-e connector to 1.3cm so I'd say 21.5 cm or 8.5".
^that image is gonna show up on fudzilla somehow, where some idiot whos name starts with C and rhymes with narlie, is gong to say it takes 1275W to power that gpu
Some prices in Holland (removed)
http://www.informatique.nl/
http://www.dinoxpc.com/public/images...7c7b8a7a_2.jpg
http://www.dinoxpc.com/public/images...6d134de6_1.jpg
Sapphire HD6870 - 255 euro vat included
Sapphire HD6850 - 189 euro vat included
that site sell Sapphire HD5850 1Gb reference for 265 euro vat included
http://img100.imageshack.us/img100/3381/gtx495.jpg
All the way back from 1 Apr 2010.
Bart is 230 mm^2 chip, slightly smaller than GF 108 that powers GTS 450, yet performs about the level of a theoritical FULL GF 104 which is 367 mm^2 in size ? Talking about added efficiency, OUCH OUCH for nVidia. :rotf:
Yep, card is exact the lenght of 16½ pci-e connectors in that pic too.
http://i55.tinypic.com/2im99wo.jpg
21.5 cm or 8.5" so you will be fine Manicdan.
