Thats what i was thinking.
And that solder may be holding the CE pin low (forceing the front bios chip to be enabled)
First thing I would do is touch the tip of your soldering iron to that blob and suck it out with a desoldering tool. Then the internal pullup resitor (if it has them) in the flash chip would pull the CE signal high, and disable that bios chip. Or heat pin1 and lift it off the pad with a needle
