Nope, it's goin to be powdercoated :)
Such a gorgeous build. Loving the green liquid under the UV lights.
A dream desk right there! :up:
Been a while, but here some new pics !
Powdercoating will have to wait a while, since we're expecting a "l3p junior" in 3 weeks :)
So here some small updates i can still do.
Been busy with different LED colors, some overclocking, and build the pumps back from 1x dual top to 2x single top.
This is how it will look after the coat job.
http://www.l3p.nl/files/Hardware/Des...deskkleur3.jpg
Some stuff from Highflow.nl
http://www.l3p.nl/files/Hardware/Des...%5B550x%5D.JPG
Other mem set to play some with the fsb for a 24/7 OC
And some OC results
http://hwbot.org/community/submissio..._980x_4900_mhz
http://hwbot.org/community/submissio...70_35184_marks
Been running with this without any problems for 2 weeks now.
http://www.l3p.nl/files/Hardware/Des...80px/ocnow.jpg
I liked the pumps more with the mods in front.
I will use this as reset switch.
IŽll use the existing one for the pumps or the leds.
And here my play session with SMD Led :)
Found out Blue with UV is the best for me.
So i'll need 3 switches to make everything work as i want
switch A - 2 x 120cm blue
switch B - 3 x 120 cm UV
switch C - 1 x 120 cm Amber
Thanks http://www.wiinds360.nl/ for sponsoring me!
Green 1 x 120 cm SMD Led
Amber 1 x 120 cm SMD Led
Red 1 x 120 cm SMD Led
Red 1 x 120 cm SMD Led + UV 3 x 120 cm SMD Led
Finishing up the leds for temporary usage in d3sk :)
480 leds in full glory :)
Amber 1 x 120 cm SMD Led + UV 3 x 120 cm SMD Led
Blue 2 x 120 cm SMD Led + UV 3 x 120 cm SMD Led
Personally i like this the most
New set of Corsair mem
Till the next little update :D
You sir are a god! Wow is all I can say at this point. :up:
Hi l3p i just seen your new desk very impressive indeed haven't been on in a few months & i was impressed when i seen your desk.
I seen one almost the same a few months back on youtube > http://www.youtube.com/watch?v=VletjNgBgZM
Hes had his for a few years thow and is just updating hardware in it. Both very alike desk, well idea of them anyways.
Take my hat off to u for a great desk. :up:
Keep up the great work.
Mate what a creation you have done, absoulately beautiful! the res your using where did u get it from? me want one :D
Thanks guys :)
I bought the res second hand on a forum. If you want one be fast, dunno if they still make them.
Its the Aquacomputer Aquatube G1/4 brass. Still available in some german shops.
Found something @ work today.
Gonna find out if i can use these to lift my glass
http://www.l3p.nl/files/Hardware/Des...%5B550x%5D.jpg
You are insanely creative! skills at this level is priceless. Builds like this revolutionize the art of PC modding. Very impressive :up:
Looking at this makes me want to build my own ;) great job!
This is one seriously cool desk, however we need more close up shots of the mobo and gfx card!!! I love how the UV lights light up the coolant.
Very impressive. Absolutely love this desk. :up:
Finally found some time for a little update ;)
Package came in this morning
Found a Corsair Dominator GT 2000mhz CL7 elpida set.
Looks easy, but isn't :)
Old and new set
Also added an UV Led strip behind the logo to lighten it up some more.
Without UV Led
With UV LED
Without UV Led
With UV LED
Got something nice from a friend @ Highflow.nl forum.
Hope it'll fit :)
Found a piece of window film/foil @ work and just had to try it :)
(Thanks for the idea Anachlores !)
-When the Leds are off, the desk should be normal black
-When the Leds are on everything should be visible.
I know this is the wrong foil, but it was only to test how it looks.
In 3 days im getting some foil samples from a friend to test further.
And bought some blocks from a friend, im totally in love with plexi now :)
outstanding project!
really makes me want to build something like it someday.
The window foil idea isn't working out very well yet.
And a real B#$@ to get the glue off the glass afterwards :)
Bought some second hand BP fittings from a friend, so i don't come short when building in the extra pump, mosfet blocks and hdd in the loop.
Also cleaned up my own leftovers.
Never build a website before, but this week i took some time for it.
All my Builds, Mods and other stuff together.
http://www.l3p.nl/wp-content/themes/...1/welcome2.jpg
Feel free to leave a message ;)
very original, actually turned out better than i thought a computer desk would look
http://lolpranks.com/wp-content/uplo...ril-fools2.jpg
And here the update of a full day scrubbing and tightening Bitspower ..
Cleaning the glass after testing with windowfoil.
Clean again.
Breaking it down.
Removed teh old SMD leds.
Ohhh no !
Oh never mind
Been puzzling for 1.5 hours before i had the right combination.
Cleaning time.
Dirt !
L3pping the 980x :)
http://www.l3p.nl/files/Hardware/Cpu...%5B550x%5D.JPG
Wtf MX-4, did i order that ?!
Thanks for the MX-4 Freddy !
30 seconds @ P400 already tired ;)
5 Minutes P400 - Total 5 Minutes
5 Minutes P400 - Total 10 Minutes
10 Minutes P400 - Total 20 Minutes
10 Minutes P400 - Total 30 Minutes
15 Minutes P400 - Total 45 Minutes
10 Minutes P600 - Total 55 Minutes
10 Minutes P800 - Total 1 hours en 5 Minutes
10 Minutes P1000 - Total 1 hours en 15 Minutes
10 Minutes P1500 - Total 1 hours en 25 Minutes
15 Minutes P2000 - Total 1 hours en 40 Minutes
20 Minutes P2500 - Total 2 hours
Had to play some with the cam ;)
Results
Idle
http://www.l3p.nl/files/Hardware/Cpu...t_idle_old.jpg
http://www.l3p.nl/files/Hardware/Cpu...t_idle_new.jpg
Stressed
http://www.l3p.nl/files/Hardware/Cpu...stress_old.jpg
http://www.l3p.nl/files/Hardware/Cpu...stress_new.jpg
And finally ...
Building it back asap, im tired :)
And some pics.
I hope it were enough pictures :D
Very nice temp drop man. well worth all the work u put in.. :up:
That is one killer desk, although I would never want to go with such a deep color in a fluid. So much gunk build up! :(
Never had any problems with gunk though.
The cpu block looks very dirty, but its the flasher that lightens up the UV-active fluid
I made an how-to lap your cpu at www.l3p.nl
I was curious about the temperatures @ stock speeds.
Can't wait till it starts to freeze in Holland ;)
http://www.l3p.nl/files/Hardware/Cpu...%5B550x%5D.jpg
