That 60C is at load with the CPUs at 4.3Ghz.. my CPUs draw a lot more power than yours so I guess the temp is ok. I can't tighten it down more, and it's mounted the right way (had to do it several times due to a mixup in the manual on which pad to use). Even with the stock air cooling, the VRM 0 temps went straight to 45C in bios for me, so I guess the sensor may be out of whack (like most sensors on this board are).
Edit: Attached idle shot :sofa:
Well.. 10s of idle time :rolleyes:
Water at 20C.
