At idle, with the ambient around 25°C I'm seeing 40 on the CPU cores and 35-36°C on the GPU cores
With 4 Folding GPU clients and SMP CPU client its reaching 60°C on the CPU cores and 50°C on the GPU's
Interestingly temps across the GPUs are even with only a 1°C difference between them whether idle or under load.
Thats with a Thermochill PA120.3 in the roof with GT 1450's, and a XSPC RX240 in the front with 2 38mm Yate Loons, all fans setup pushing into the case through the rad, and then a single 38mm Yate Loon pushing air out at the back.
Still sounds like I've got some air locks in the loop by the gravel sounds in the res.
