Beep: no, diferent coolers, but thinking, temps for some 2D benchmarks was simillary
Awesome...really awesome!!!Does this hack work with all amd chipsets??
Did you get quad SLI to work? Do you use the SLI bridge with your TRI-SLI setup with the hack? I tried it on the MSI 790FX-GD70 a few months ago with three GTX 260's and it worked without the bridge in that test (TRI-SLI). Funny thing was when I installed the bridge later the system wouldn't load Windows.
My OS works with the bridge.
4 way is a no go, seems to need somewhat extensive hacking to enable 4 way.
I haven't done enough testing yet to determine or calculate what a score will be on ln2 yet, i think it will be close to 2x 5970's but not enough if only using air.
Ln2 could get complicated as the OS when hacked seems to be somewhat "fragile"
