Thanks for the heads up, order placed :D
I had messaged Mudgey a few weeks back about a 120mm stand. He said he is working on a new revision. Hopefully he will have some available shortly.
Hi guys,
I only have one 140mm rad stand left and no 120mm versions.
The revised version will fix the compatibility issue with the SR-1 where it will only fit with the barbs facing outwards and not inwards, and the 120mm version will be redesigned with the same construction method as the 140mm version. I will also make a few dual rad units that will hold two rads side by side.
I ordered some replacement centre section plates for the 140 stands that solve the compatibility issue with the SR-1, however I made an error with my scaling and they came out 1.5x the size they should have been!! ops.
The next large laser order should be in a few weeks where I will get the profiles made for the 140's, 120's, duals and for the prototype cube case.
Regards,
Mudgey
I have one of Mudgey's 140mm stands here.
Ordered and then decided I have no use for it.
Box opened but parts not even unwrapped.
It's available and I'm located in NH in the US..
Thats right, the centre plate would be wider, the base would be wider, there would be another side plate and another two aluminium feet in the centre also. Unfortunately there will be a slight gap between the rads as it seems most rads are of varying thicknesses. The central support plates would slot together so the distance between the rads will be kept to a minimum, there would also be a plate that would attach to the top of the rads to keep them parallel to each other, if you wanted I could extend it higher and make it into a handle for carrying?
The plate across the top, would that mount on say the fan holes? If it does i'd make it to mount on all 8 of them, keeping the thing solid and ridged. The Idea of making it into a handel is cool. Shall i order a 2nd SR1-560 and send both of mine to you so you can play with it? Im more than happy too. I really like the idea of the dual. I think this could be idea for a lot of different events and setups. Shall we go to PM?
Edit:-
There back instock now as well http://specialtech.co.uk/spshop/cust...64&cat=0&page=
Hi,
As you said it, the top plate would mount the top most fan holes (all 4 holes per top fan) and span the width of both rads.
Thanks for the offer, that would really help with measurements however I would only require one SR-1 to measure from! I'll PM you my address.
I like the idea of the Dual. Will that be 120mm or 140mm?
I've been considering how to get dual quad rads into a workable single or double loop and not many if any can accommodate that much radiator.
I'm looking forward to this case you speak of!
why the Rad's inlet and outlet at the bottom ? shouldn't they be up for better flow ?
Got my Thermochill PA140.3 today, and my Mudgey stand is in the mail. Can't wait to see my plans come together!
140mm Rad Stands are finally back in :)
Image 2:
1st - Sorry for poor photos, using iPhone!
At last i finaly got it all put togther. It's amazing to look at! Huge huge thanks to Adfam for his skills, product, talks. :yepp:
I need to work out how i'm going to join the fans in the best way, thinking remove the tacho wire, attach the fans the other way around and join the wires behind, cut, melt, solder in, heat shrink. Make it proper and neat.
I hope the rad bleeds okay in this postion, no bleed port on top.
This is the new version of the 140mm stand! The line on the babr fitting on the rad shows issue with the old version. Adam was right on the ball with this!
I've just been toying with mounting a fill port on there, thinking of also putting dual pumps (DDC's) on there and the fans cooling it, 1ft of tubing off the rads then quick links and it being a mobile, portable benching water thing! Also just nice and confind but working out whats the best way is not so easy!
Setup here is the following...
HW Labs Black Ice SR-1 560
Yate Loon D14SH-12
Danger Den Fatboy's 1/2''
Tygon 3/8'' (yes i boild it and use my bodybuilding lifting power to fit it on)
Small update, i've sorted the fan wiring out and it works, but there piggy backed which i see and now know is a no no so i will have to sort that. I was thinking of fitting 4 more fans but will just go for the higher cfm and stick with 4
Tetra, You might want to look at this.
http://www.xtremesystems.org/forums/...7&postcount=16
Thanks man, i've done it now and done it wrong but it works. I'm going to upgrade the fans anyway to higher CFM for the application im going to use them for. I will pull rpm wsire, just heatshrink each cable in length to the base then join all 4 into 1, or 8 pending if i go push and pull.
Wired the fans, done it wrong. They work but they piggy back of each. I want to go higher CFM so i will just have the wires all the same length, the into one. Just gotta sort what fan i want now! How i did it was to run a blade tip of the iorn on the wire to melt off some insualtion, then tin both wires, hold them close and apply some heat. It workd! Again sorry for pants photos, iphone. DSLR is dead
¿The 140 versión it's 100% compatible with the HW Labs Black Ice SR-1 560 rad?
I see in the photos that the fitting conector touch the estructure.
I've already located on Ebay and I want to buy a unit.
¿This item its discontinued?
Hey guys, I have discontinued these stands as I was selling them at cost. They were quite expensive to make here in the UK, I had a max price in mind but I could not get the production costs below it whilst having them made within the UK. I have been concentrating on making some PC cases instead and who knows, I may reintroduce a 3rd revision of these stands later down the road!
Nicely done on this piece of hardware. Great design.
