My "F" died after 15 minutes on LN2... new box retail...
oh bad luck guys :(
Hope the next to be better :D
I got 3013A472 which sucks... waiting for 3003B475
that really sucks man:(
but try this.......
if you have another 980 laying around pop it in the board and go to BIOS and disable HT.
Reboot then power down and pop in your golden 980. It might just be that your HT died and you still have a CPU that can do some 05/AM3/32M damage....
It has worked for me....it's worth a shot:up:
Oooo :( sucks big time :down:
I tested with Brian's trick but no way to power up the CPU...
Maybe the WPrime 32M runs on EX58-UD5 where to heavy, this was the only time where we use HT - ON and 6 Core Load
Wtf :(:(
wprime is extremely heavy for the processor, 1024 is a killer, makes every other test except vantage look like a walk in the park... I do believe wprime is a tad more stressful then vantage...
Does it post more then FF, any cycle before?
damn too bad the chip died...tried only booting 2 cores no HT?
Have you tried to bootup at a higher Vcore like 1.3V to 1.4V ? ( either with a modded BIOS, or by setting up the BIOS with another CPU )
Yes... the XPower have a overvoltage switch... so we tested with +0,1V extra VCore... but no boot :(
Did you check the voltage it applied though ?
Because I have seen the Classified & R3E POSTING at... 1.05V with the Gulftowns.
f batch is very good but die quickly:(
Anyone else go results for 3013A472?
They just hit the shores in Indonesia
I have got one, and is the most terrible Gulf which I have. 5.6 Ghz 3dmark 06 max... vantage doesn't pass even on 5.3 ghz...
I got mine also from RMA, today I send another chip on RMA so I guess I shall get another 3013A472, I am waiting for your results!
End of the code does not hide the importance of,I tried two of them 3005F213 One good other bad.This aleatoric...
i find this on the net i have one same cpu that never open i just test 3005f210 and good on 6150 on 05
here the result from 3013a472
https://blog.so-net.ne.jp/_images/bl...4MHz-8a4c1.jpg
https://blog.so-net.ne.jp/_images/bl...s206267MHz.jpg
i think it pass more than 6250 on 05
link :
i found 3013A472 in my country, but already sold =x
