this thread is co good crazy....3300+ MHz NB ?!!! 4700MHz superpi, RAMs...
I have to say; I am impressed with the MSI board from reading this thread. I thought the board was much slower than the CHIV at first, but it looks to handle itself quite well. I still am partial to Asus over MSI, but I can't say the MSI is terrible. If I wasn't waiting for the CHIV Extreme I would have a tough decision between the Formula and the GD70.
:rofl::rofl::rofl:
If I read this thread earlier, I would have gone for 4.952GHz & PI1m @ 4.72GHz. Now, I'm 2MHz behind you...ok, I need to catch up then !
It was sooooooo entertaining....1st with namegt & now with you, Chew :up:
My pleasure....:D
Oh...BTW, have you heard about the little bug from an AMD article about Thuban running 1333 scale ?
MSI GD70 is the next mobo I'll test ;)
See you tomorrow ! need to go to beeeeed !
i just bought this mobo why does the link width only x8 not x16???
@chew
can you give me guide for the bios ,how to run x6 stable @ 4ghz
mine cannot pass intel burn test always blank screen, please need help
And if I want to raise my nb freq,
What should I raise
Cpu-nb voltage or nb voltage?
Sorry if I ask to much,
And what nb voltage use for?
On the off chance that a waterblock is made for the PWM and NB area of this board, with your best guess, would this comfort you enough to load a 6 core fully for extended periods of time?
I've got a PWM block for the 790FX GD70, I assume that it will fit the 890FX variant as they share the same PWM and heatpipe setup. I don't have both boards on hand but I get paid the 10th and the 890FX should be coming my way. I will post some pics once it's good.
Prime does nasty things to cheap boards and while the 890FX-GD70 might be an awesome board in alot of ways, it only has a 4+1 phase PWM. With a ~180w load (About 4 Ghz with 1.475v) That puts 45w on each primary phase. These are not heavy-duty volterra phases that EVGA uses on it's $400 Classified boards. They aren't built to withstand 45w on each phase. More like 35.
He doesn't want to kill Dumo's board...and even though a waterblock lowers PWM temps it's really no guarantee that the parts will hold up over rated spec.
i primed 4.1ghz@1.475v on the 790fx gd70. i bet this board can handle this too, if u cool the pwm properly. thereīs a screenshot of 1hr prime blend in the gd70 thread.
iīm sure that the ones that fried their pwm either didnīt cool them, or they enabled some power saving functions in the bios that made the pwm go crazy.
@beepbeep2: the 1090t i have draws less power than my old 965 c2. and the tiny 4+1 pwm handled the c2 with 4ghz@1.535v just fine. maybe iīm just lucky, i donīt want anyone to fry his board by running stupid prime.
but saying that a thuban draws more power than the old 140w denebs just isnīt right.
not 100%
but one cap on the 890 gd70 is closer to the nb heatsink, than it was on the 790 gd70.
890fx gd70
http://www.abload.de/img/msi_890fx_gd70_1x5co.jpeg
790fx gd70
http://www.abload.de/img/five_pictures1_2010032nux4.jpg
i didnt think they were that bad w/ x4, hella people had that board & i never really saw complaints here. there has already been more fried boards w/ x6 than there was the entire time gd70 was around w/ x4..
i primed the :banana::banana::banana::banana: out of my 790fx-gd70 w/ 965c3 x4 (1.6v+) and never had problems, just didnt want to take the chance w/ x6
edit: and i thought i read one time that msi 4+1 is basically the same as asus "8+2" but just labeled differently.
Thats a picture of a prototype board. The board looks different in retail. :yepp:
/end quote comment
Here is what I'm talking about the 4+1 PWM:
MSI 890FX-GD70:
http://img155.imageshack.us/img155/5856/msi890fxpwm.jpg
ASUS Crosshair IV Formula:
http://img63.imageshack.us/img63/9842/asus890fxpwm.jpg
ASUS M4A89TD Pro/USB3:
http://img691.imageshack.us/img691/5...la890fxpwm.jpg
Gigabyte 890FXA-UD5:
http://img163.imageshack.us/img163/1...90fxud5pwm.jpg
Chew*,i have read a review on this board over hear in the UK,saying that early bios's dont have the option to disable "turbo core",is this correct,and has this option been dealt with in later bios's,as i am considering giving one a go,as i have 2 790fx gd70's,and never had any problems with MSI boards.Thank's in advance.:)
