CHECK BELOW FOR UPDATE! My setup has changed drastically!
Alright here is an update to the watercooling setup:
FrozenQ Liquid Fusion 250ml Reservoir Side Port Edition <-- One question for this, does it matter where the water enters from?
XSPC Dual DDC Clear Acrylic Top
Magicool Xtreme 240mm Radiator
Magicool Xtreme 480mm Radiator *Koolance QDC OUT
EK Supreme HF Gold Edition Block *90 degree adapter out
EK X58 Classified Full Board Northbridge/Southbridge Water Block
XSPC RX Series 120mm Radiator *Koolance QDC OUT
2x EK-FC480 Waterblocks *90 degree adapter OUT
XSPC RX Series 120mm Radiator *Koolance QDC IN
Bitspower HDD Acetal+Nickel Top Water Block
Back to res with that adapter thing Shoggy mentioned (thanks man!)
*NOTE - All items above are in order of how water will flow starting from the res and going back of course
That must've covered everything...
Gonna be using a mcubed to maintain low fan speeds.
Gonna order some NZXT Single Sleeved extension cables, not gonna sleeve them myself. Maybe after the build is finished...
Going to use PrimoFlex Pro LRT Black Tubing -1/2in. ID X 3/4in. OD with PrimoChill Anti-Kink Coils - Clear
Also, 20 of these Bitspower Premium G1/4" Black Sparkle High Flow 1/2" Compression Fitting (For Tygon 1/2" ID). A few extras of course xD
Planning to mount the Dual Pumps vertically right in front of the Magicool 240mm Radiator (just to the right of the inlet) on top of some AcoustiPack™ EXTRA - Foam Blocks Soundproofing Material. Should reduce noise but am worried about heat buildup. Also planning on mounting the OCZ Vertex 2 SSD on the middle 5 1/4" bay (facing outwards) with a (UN)Designs X Bracket Vertical Rev 1. Finally gonna use this Lian Li PC-343B Radiator Brackets to mount one of the XSPC 120mm radiators in the upper portion of the ODD area. This radiator won't be getting much air flow I know, but it's only there to help me manage the tubing (and have it routed nicely).
Some other stuff as well.
Gonna mount that BP HDD block in one of the lower 5 1/4" bays with this SilenX 5.25" Luxurae Hard Drive Cooler and Silencing Solution. Not sure how good it'll do but should be sufficient. Just thinking also to keep the Dual Pumps up with a (UN)Designs Infinite Pump Bracket (for DDC pumps) - Vertical Version.
A few other things... A Koolance Drain Valve (1/2") mounted somewhere at the bottom of the case, AND finally, three sets of Koolance QDC (High Flow) No-Spill Shutoff, Male + female [For ID: 13mm (1/2"); OD: 19mm (3/4")] These are the Koolance VL3N versions which feature a NO-Spill design (a bit more restrictive though).
The fans that I'll be using, 8x Blacknoise Noiseblocker Multiframe S-Series M12-S3 73 CFM. Expensive fans at 23 a pop but feature the least noise at 12V. Won't be running at those speeds but the possibility is there.
I think that covers everything...
All parts are coming from Performance-PCS. I heard that they only have a handful of employees, hope they don't get the order messed up.
**See some MSI GTX 480's available, gonna get 'em ASAP**
