:shocked: Congratz! Sick results. How much of a difference was there between load/idle on LN2 with that monster?
If you mean temperatures, not much.
Current pot design can hold load really well and drop is like max 10c in 1024M Wprime. During Vantage CPU test worst temperatures were around -177C°.
Wow that's not much. Good work!
an excellent result!!!!:shocked:
By the way.. I did some final tuning for my CPU pot design. Now the design is ready to be published :up:
What's the batch number of this CPU?
This is ES CPU, so the batch is not important I guess :shrug:
so when we will see cpu pot and new scores ? :D
take your time SF3D! ;)
what about pot ? :P
Pot will be soon :) First I must sharpen my penknife :D
Lol ^^^^....great stuff Petri, that must have been a real buzz that day getting those scores.
that is one sick mofo of a CPU
wish mine would work past -150 as it scaled with cold up to that :D
what sort of vcore were you getting through that vantage run at 6090Mhz? was it similar to CPUs or lower/higher?
I did not measure the exact voltages during heavy load, but it should be pretty close to what it is in the pictures. CPU test can be passed at 6180MHz and 1.893V, but a little bit lower freq and Vcore with 4 x GPU.
Yes, my Q3QP was doing over 6500MHz on 2D, but it was too hard to control with fluctuatinc cold bug around -145C° - -155C° :D This is so easy to use.. just like AMD :p:
it's a tricky temp around 155 cause next slightly bad poor and you could be looking at -170 :rofl: if you did at least one overfill before heheheh
with -150 to -155 on my setup i just dont want the pot to see above that so that its harder for the temp to go much lower and is all good heheh
one thing i liked about UD7 is no matter what type of crash and restart i had i didnt have to reset the machine or deal with CBB it would fire up every time with my OC settings and be stable which was nice for a change lol....nothing worse than needing to bring the temp up without a torch lol to fire up again heheheh...that :banana::banana::banana::banana:s me
5mo of hell...ouch :D
You'll still go and play with the samples next time around though :p
Awesome power of Gulftown and nice speeds. Waiting more results :toast:
Awesome Petri ! :toast: and i like your pot....
Exactly! Actually my current pot can be controlled easily at those temps, but you would need to have slave for doing it :) Or else you will have sore wrist pretty soon :p:
Sounds nice! I hope to see that board in my house soon.
Well, maybe some of UK overclockers will visit us in there :up:
Mark! I need markencoder V.1.0 to read your post :D
Thanks! New scores are coming sooner or later ;)
Thanks! That is the old revision in the pic. New product looks slightly different and perform even better :cool:
Amazing freaking scores!!!
Nice scores! How is gonna act the pot on DICE? and the price :up:
