I used the easytune6 just for tweaking in stability and then transferred the settings to bios
radaja: you have any results yet?
no not yet.so does ET6 not show MB temp in the hardware monitoring tab on this board?
No, seems like speedfan does though (along with one other). Everest is normally the best for showing all the temps on a board from my experience, but not certain it's up to date for this board yet, probably is though :)
Can anyone tell me at around what bclk you need to start using the skews? I've seem some mention of using 300ps on the CPU but I'm getting hangs. Does the other skew (IOH is it?) need to change too? I would test & find out for myself but time is really limited at work :/
I have only went to 4.4Ghz, 24 hour Prime95 stable, with a 920, I needed no skews. 6Gb RAM
What bios is everyone running, is there one that is stand out better than the rest or just go for the latest?
yea everest is great for temps.it shows MB and NB sensors,but im wondering why ET6 doesnt show MB temps
i mean the sensor is there why not show it?
My version of everest, 5.3.1900 , has the MB and CPU temps swapped and only reports on two core temps. Other than that it works just fine.
Let's face it, the majority of ET6 versions are complete s**t. I had to go through about 6 versions before I found one that worked on my Extreme, issues ranged from setting ram to default voltage every time I clicked 'set', hanging, not loading at all and the usual GFX driver issues. It's really handy when it works, but the version they have on their site for the extreme didn't work at all (b10.xxxx), ended up on B9.xxxx. Would rather use speedfan anyday - less resources, better presentation of temps etc, if only it could tune voltages!
What sort of MCH temps are you lot looking for? I'm seeing 69C in the BIOS.
mine was burning hot, added a fan to blow over it. now nice and cool.... That is about my only complaint with this board
Mines also quiet hot, haven't decided on how to cool it down yet though.
mines cool but i do use AC blowing into the case.w/o Ac it runs about 27c-32c
http://i42.tinypic.com/29f2gbt.jpg
http://i40.tinypic.com/9itv2v.jpg
Mines typically around 46-48C....probably going to end up watching the board die in summer lol.
Yeah, I hope it doesn't, my IOH temps are somewhat high too, and that's with the case open. I imagine it would suffer even more with a powerful gaming card in there to utilise some of the PCIE bandwidth. Don't think it's coming from the mosfets either as I'm running v. low volts where I can. Should have a screenie when I get into work shortly if it's still testing at <1.1v/3.5GHz :)
Trail period of Everest has run out so I'm using speedfan. Which one do you reckon is which out ot Temp 1,2 and 3?
http://img580.imageshack.us/img580/9428/speedfanr.jpg
radaja, would you mind comparing Everest with Speedfan for me to work out which is MCH?
Oddly enough my temps are a couple C lower with the case side on. My 930 is pig too taking 1.3v @ 3.9Ghz which definitely doesn't help.
wolvers69, As far as I know speedfan doesn't work on this MB, it's readings were way lower than what real temp and everest reported. Try to find an older version of everest, they used to be indefinite trials.
wolvers69,here you go.
temp 1 is MB
temp 2 is Cpu
temp 3 is NB
http://i43.tinypic.com/20pf0hz.jpg
curios to see what my NB temps were I downloaded spdfan and have 45 for a temperature. I also have a 80mm fan sitting on top of my VC blowing air across the NB
radaja, thanks for doing that. :) It confirms what I thought, that the lack of air flow inside my case is causing the motherboard to run hot, particularly the NB to beyond 70C in stress testing.
This photo shows why. I've watercooled a Silverstone CW02 HTPC case! :p:
http://img710.imageshack.us/img710/2905/cimg0001xl.jpg
I guess I'll have to pop a fan in there to spot cool the mobo. It's certainly worth doing, so far I've got to 3.8ghz with 1.22vcore which seems fairly reasonable to me.
4.47GHz Stable @ 1.41V HT enabled.
http://i435.photobucket.com/albums/qq77/AAdeath/447.png
hahah don't you hate it when it fails the last pass, so much false hope.
